Laney's new Ironheart IRT-X extension cab.
GrumpyrockerGrumpyrocker Frets: 4146
What is the Ironheart IRT-X? Some sort of extension cab/PA speaker for your amps that has its own stereo FX loop. You can use it as a monitor. Or use it to create a wet/dry rig. It's probably not something I need, but it's interesting anyway. Check out the link below.
Apparently Alex Hutchins has been demoing this at NAMM but it's not live on the Laney website yet. However it is in the Google cache so you can see it.
  • This could be a cool product if it sounds good.
    It basically gives you the option to run your own monitor that points at you, rather than throws into the crowd.
    Also it has a cab emulated line out, which could be really useful too, if it sounds good.
    It seems like an FRFR type speaker with cab sim and FX loop built in.
    You can already get these products individually (DI with speaker sim, FRFR speakers) but having them in one product aimed at guitarists seems a decent pitch for a product.  Hope it sounds good.
