Twisted Imaginings - A Horror And Gore Themed Blog http://bit.ly/2DF1NYi
More seriously, what plunger have you got? If it's a little Dalek plunger, they're mostly crap. I bought a cracking one from Screwfix last year which proved to be excellent at unblocking the home sink and the sinks in my restaurant kitchen.
I guess it depends where the blockage is, if it's in the pipes between the sink and the main sewer then a proper plunger should clear it (we have a turbo plunger, which utilises a flux capacitor to really ramp up the plunge powah) and when that fails, dry caustic soda, which clears up the fatty deposits.
If it's beyond the point where the sink drains to the mains, then you probably need to clear the main, that means using drain rods (lovely job, mmmm shit covered flexible pipes) or I believe you can get chemicals to clear it.
http://www.screwfix.com/p/sink-bath-unblocker/13894?_requestid=279504
True, I nearly died, and both sets of neighbours have since moved out, but the drains run freely.
it is possible that you were the teller/victim in the cautionary tale that warned me about using chemicals down sewer mains.
best unblocker .......leave in plughole for 3 minutes then run a glassful of water
a bad blockage may need to sit for a few hours
then flush through
OMFG
I put it in the watering can and started sprinkling... about 5 minutes in I couldn't breathe. I kept going, like you do.
Never, ever, again. Eyes went, throat went, I thought I'd done serious irreversible damage. To me, not the lawn.
For a fortnight you could smell my lawn from a block away. It was totally salt and vinegar. I have no idea how I wasn't reported to the council.
Beware chemicals.
I tried cleaning out the u-bend, used plungers till they broke, one of those flexible metal rod things.... I suspect I've poured so much Mr Muscle down the fucking pipe that it's totally solidified.
Probably the only way to sort it, I think, would be to take a ladder and go up to the point where it joins the outside drain, then rod out that part of the piping. But I can't be arsed.
