You have ONE distortion/overdrive.. What's it gonna be?
  • GassageGassage Frets: 30927
    I/d want something v vers....Effectrode Blackbird
  • JD50JD50 Frets: 659
    rico said:
    m_c said:
    equalsql said:
    Is it still a six month waiting list?
    No.
    It's currently about a 17 month wait. - http://www.analogman.com/kotdelay.htm
    That is ridiculous. Are there KoT clones out there?
    Is the circuit not based on Tubescreamer?
  • ICBMICBM Frets: 72411
    It's a Marshall Bluesbreaker MkI.
  • equalsqlequalsql Frets: 6137
    edited March 2017
    rico said:
    m_c said:
    No.
    If you're into soldering @rico then Rullywow​ do the Queen of Bone pcb for $14. It's​ an impressive little pcb.
    http://www.rullywow.com/wp-content/uploads/2016/07/3D-PCB-no-components.png
  • sgosdensgosden Frets: 1994
    Had a similar situation when my amp died during line check, 2 minutes before we were meant to start. My backup was in the van. I was graciously loaned another bands back up amp, a masrhall MG combo (which was luckily on stage anyway as there head had also blown).
    Very glad I had the EQD palisades on my board.
    Normally use it to push the amp OD harder, but though the line check and first few songs had dialled in 2 useable tones. By no means was it the best I've sounded on stage. But it got us through the set!
  • stickyfiddlestickyfiddle Frets: 27099
    Rat, almost certainly. It's my "home" pedal by a long way. That said, I played my JM through a Rockett Archer into my BadCat last night and it was GLORIOUS, so depending on the gig I might choose that.
  • VaiaiVaiai Frets: 530
    KoT/Van Weelden Royal Overdrive (so many options in one box!) or Angry Charlie
  • Dave_VaderDave_Vader Frets: 360
    Have done this with just a Harley Benton Vintage Overdrive (like a Joyo Tuescreamer clone) and an old red-knob fender.
    Sounds glorious.
    Have also done it with a mooer black secret (RAT clone) and my WEM, also glorious.
    I like cheap pedals.
  • mr_airmr_air Frets: 24
    MI Audio Crossover Drive
  • edenfield99edenfield99 Frets: 349
    Fuzz Face
  • dogloaddogload Frets: 1495
    I think, based on stuff I know, I'd have either the Nobels ODR-1+, or a Valvesporker.
  • DominicDominic Frets: 16103
    Lazy J cruiser Deuce
  • JalapenoJalapeno Frets: 6393
    TRex Moller </predictable>
    Those wanting something to cover KoT - checkout the KoT alternatives That Pedal Show video.
    Moller from 28:28
    Feedback
  • english_bobenglish_bob Frets: 5158
    If I get a soundcheck I'd probably try a couple of different ones.
    ZIM would be a very good shout- two channels, flexible EQ.
    RAT would be in the running.
    I'd also consider a Skreddy Screwdriver. Constantly impressed at how many sounds come out as you turn the knobs.
    if it was a festival gig or something, and it was just get on stage, plug in, play, get off, I'd probably go for the ZIM.
    I still get to take my delay pedal too, right?
  • ReverendReverend Frets: 5002
    What albums has the KoT been used on?
  • professorbenprofessorben Frets: 5105
    None, it's an agreement you can only use it in small to medium sized pubs.
    Kenny Wayne Shephard will have used it on a bunch of recordings by now
  • John_PJohn_P Frets: 2750
    Steve Rothery used one for most of the lead parts on his solo album.
  • gibsongretschfangibsongretschfan Frets: 1050
    edited March 2017
    Double
  • WazmeisterWazmeister Frets: 9555
    I currently now have just one on my board... @ThorpyFX Veteran.
    Just one. It is that good.
    High gain, low gain, bit o' hair - it just nails my sound.
