I'm tempted by the new Boss one because it can work on two pedals but it's £85 which, for me, would be a lot of money for a tiny improvement in functionality.
It's not going to be my weapon of choice if I'm ever called upon to beat a man to death with one of my pedals (I reckon a wah pedal would be best), but it only cost £14.
Worth confirming with Bogner and/or interwebs forums that whatever you plan to choose will definitely work with your pedal- I don't think expression pedals are all exactly the same- I had to mod mine to work with my M5.
Quick google suggests the M audio is 10k ohm, if that's right it wouldn't meet Bogner's spec which, as I understand it, doesn't mean it won't work, just means it might not work.
EDIT: scrap that question it seems the pedal comes with a TRS cable anyway.
I had to mod mine to work with the Line 6 M5- there's a resistor in series with the pot in the pedal, so when it's at maximum it's not *really* at the maximum value of the pot. You need to cut one end of the resistor and bridge the connections with another wire. It's a five minute job.
Build quality is maybe slightly better than I expected- it doesn't feel quite as flimsy as the Bespeco volume pedal I bought years back to control my DL-4 but it's certainly not something you'd describe as "heavy duty".
Website || Feedback Thread || PayPal
