Which Won Would Wou Wah With??
  • danodano Frets: 1593
    I wah woth left foot, wah left of board. Probably cause I'm a lefty that plays right-handed
  • mike_l said:
    I use 2 wahs.
     Both at the same time.
    I tend to fall over a lot though..........
    WaahhHawwAHhWah.
  • ReverendReverend Frets: 5001
    Reverend said:
    Left foot as the wah is last butbine in the chain.
    Are you getting all your dirt from the amp?
    A mix of amp and drive pedal.  Wah before dirt means I don't really hear the wah much.
  • professorbenprofessorben Frets: 5105
    Hmmm I might experiment with this idea so I'm guessing you go
    pedal dirt
    Wah
    amp dirt
  • HogwashHogwash Frets: 4
    edited April 2017
    lukedlb said:
    Left input wahs exist. I had a vox one from the early 70s. I suspect it was for a keyboard but it was as good as my other wahs except for the fact that it was a lefty.
    Eric Johnson says he can hear a difference, ceteris paribus. Lance Keltner will probably back him up on this at some point, too. Rather more contentious, possibly, is EJ's assertion that whether the power cord on an amp is fixed or detachable also has a bearing on tone. Yes you read that right!
    If Chaos theory is correct, anything and everything can have an impact on the tone of your amp, including the ambient temperature of the Generator/Reactor in the power station, how measurable those things are I'm not sure.
    All I know is that if I measure the voltage at the socket on any given day, I'll get readings between 230v-250v, I'm pretty big sure that's got to have an affect on the amp at some point.
    Pretty big sure.
    You know, like fairly massive confidant!!
  • mike_lmike_l Frets: 5700
    mike_l said:
    I use 2 wahs.
    WaahhHawwAHhWah.
    That's almost exactly how it sounds. Kirk Hamster is jealous.
  • 57Deluxe57Deluxe Frets: 7339
    either - but I may have to take my shoes off first...!
    <Vintage BOSS Upgrades>
  • I don't use wah much, but when I do I generally prefer to use my middle leg.
    You have a CryBaby Mini I presume???
