Hi-Fi Amp Humming
Greetings
Slightly off-topic but I know that you lot will probably have some useful advice on this.
After twenty years service my faithful Cambridge Audio amp has started humming/buzzing when you turn it on. It happens regardless of which source is selected and is independent of the volume control.
Any ideas?
  • GassageGassage Frets: 30931
    Give it a copy of the lyrics then it won't need to hum....
  • ICBMICBM Frets: 72494
    Probably a filter cap or a broken connection in the ground path somewhere. Does it do it on both speakers?
  • UnclePsychosisUnclePsychosis Frets: 12924
    Sorry, should have been clearer. It's not coming out the speakers - it's the actual amp itself that hums.
    If it's a physical hum it sounds like a loose transformer mounting, or de-lamination.
  • 4114Effects4114Effects Frets: 3131
    Just turn up the music until you can't hear the humming. Simple.
