Which 6v6's?
bandmaster188bandmaster188 Frets: 391
Was just about to order some tungsol 6v6s for my new amp but have just read in another thread that they can be noisy.
any recommendations for a decent current production 6v6.
cheers!
The Swamp City Shakers
  • horseheadhorsehead Frets: 220
    I've got some tung sols in a Drri and I've noticed no noise at all
  • Modulus_AmpsModulus_Amps Frets: 2583
    noisy power tube?? only if they are not matched there and thereabouts or there is a fault of sort, 6V6's should run very quiet in a well built amp.
  • I have 2 JJ 6v6 in amp and very pleased with them.Have spare EHX set of two as well,but never tried.
  • noisy power tube?? only if they are not matched there and thereabouts or there is a fault of sort, 6V6's should run very quiet in a well built amp.
    Looks like I misread the other thread. They were talking about tung sol preamp valves being a bit hissy.
    From what I've gathered elsewhere, the jj's seem to be the most reliable but the tung souls sound better. Might have to try a set of each.
  • deadstringdeadstring Frets: 3
    edited April 2017
    JJ 6V6  good but not really a traditional 6v6 closer to 6L6
    EHX have changed production, old ones were excellent, newer ones began to fail/noise on me a year in.
    Tung Sol supposedly noisy prone to failure?, excellent 12ax7 preamp tubes tho. Buy from a seller
    who tests etc..
    TAD 6V6 so far so good they sound excellent. Seem to have a larger base and fatter pins, fairly tight fit
    snapped a bear clip inserting these.
  • JJ 6V6  good but not really a traditional 6v6 closer to 6L6
    who tests etc..
    Thanks !
