I had 10 at one point!
I know I should go further & sell one of the 3 as i hardly ever play it- a LP and a tele are all anyone could need.
(Let the flaming commence).
The Guitar Grounds Gassathon?
same, tho the electric doesn't get played. So I guess from a playing POV I only have one guitar.
EDIT: I like just having the one TBH, I don't worry about whether I sound like this player or that band, whther I need a dread, or a parlour, whether I should have a RW guitar and so on. I just play the thing.
Try to understand that Snowy White or Justin Hayward would probably not have wanted to swop with you.
PRS Cu22
and a CE24.
I could prob get away with just a CU24 but the neck pickup is sooooo much nicer on 22fret guitars.
The Bolton is a bit snappier and brighter as its Alder bodied.
The Glued neck is a tad darker and thicker, mahogany body and different pickups.
But I could easily gig either one all night, the other is literally a spare.
It's only since being on this forum that I started to feel inadequate in the guitar department and since I gave up gigging that I started to acquire more.
Mind you, I've got shitloads of banjos but only because I buy them and fix'em up and I find them more interesting than guitars.
