DiMarzio custom taper 500k pots. Anyone tried them?
BowynMadleyBowynMadley Frets: 152
Frankly I'm a fussy bastard. I'm looking for a pot that has a nice smooth taper from 0-10. My amp cleans up very easily when rolling off. The current 550k cts has a very sharp taper from 10-8 meaning It can go from clean to lead in the last 5th of the turn.
Has anyone had any experience with the above mentioned DiMarzio pots?
Thanks
Bo
  • AndyRAndyR Frets: 158
    No experience of the DiMarzio pots but I got what I wanted (and what you're describing) by switching to linear taper volume controls.
    I figured it out a about 18 months ago. Why did my Les Paul Traditional clean up so nicely but stayed at nearly the same volume all the way down to 3 or so? My other guitars with the expensive replacement pots were almost on-off switches (between 8-10) in comparison.
    Eventually, I found out that Gibson had put linear taper pots on the volumes. I'm gradually switching all my guitars over - SO much better for what I want.
  • ICBMICBM Frets: 72415
    You can also change the taper by adding a resistor between the top two terminals on the pots (ie the non-grounded ones). Typically if you have a 500K Log pot, a 100K, 150K or 220K resistor will probably be about right - they're so cheap you can easily experiment with a few values.
    The only disadvantage is that you will get a bit more treble loss at low volume settings because the effective load resistance of the pot has decreased.
  • DanielsguitarsDanielsguitars Frets: 3297
    edited April 2017 tFB Trader
    Ive been using linear volume pots for years for that very reason
    I haven't found one audio taper I like yet and I'm not trying anymore out
    www.danielsguitars.co.uk
    (formerly customkits)
  • BowynMadleyBowynMadley Frets: 152
    ICBM said:8
    That makes a lot of sense actually. Any ideas where I could buy them in singles or atleast in small amounts? Don't really want to buy 10 or 25 of the buggers haha
    Maplins sell them individually - they're far from the cheapest if you're buying in larger quantities, but at the price resistors are it doesn't make a lot of difference for your purposes.
    http://www.maplin.co.uk/c/components/resistors#Category:Metal Film Resistors&sort=price-asc&page=0&productsPerPage=showAll
    You only need the lowest power rating - their 0.6W metal film ones are ideal. 9p each by the look of it!
  • HeadphonesHeadphones Frets: 992
    I suggest that the reason you're preferring the linear, is because you're not using it as a volume pot.  Stay with me...
    A log pot works (in most sound situations) as it directly controls the volume of output - and your ears respond in a logarithmic like fashion, so a log pot is what you want for that role - so it appears to act in a "linear" fashion.  The two logs cancel out if you will.
    However, what's going on here is quite different.  If you were playing clean and just after volume, a log is what you'd want.  But what's actually hapenning is your using it as a distortion control for the amp.
    Once you're out of the clean part of the performance, the output wave form in a guitar amp won't get any taller, but it will become more distorted (and therefore sound louder and add more overtones).  SInce this distortion is proportional to the input signal - that is, it has a linear relationship - a log pot won't suit well, since all the change is at one end (by design) and it will feel (as you describe) like a switch.  So a linear pot will work better.
    In other words - clean volmue control - log; distortion "volume" control - linear.
