Which pedals on your board are always ON ?
TelejesterTelejester Frets: 743
On my board I have a t rex jr power supply and the pedals connected are:
Sonic Research ST300 turbo tuner mini
TC Electronics Sentry noise gate
CAE Wah
Maxon OD 808 reissue overdrive
Diamond CP1 compressor
Tone City summer orange phaser
MXR 234 analogue chorus
Boss DM2 waza analogue delay
All my pedals get switched on or off regularly depending on the song , but only ONE is left on permanently and that is my Diamond CP1 compressor which i just couldnt imagine not having. Despite the number of pedals you use, are there any always on type(s) regardless of the song ?
«13
  • KebabkidKebabkid Frets: 3312
    My Keeley Compressor but of late, when using one of my Strats with lower output pickups, my Xotic EP Boost is also being left on.
  • TheMarlinTheMarlin Frets: 7886
    Simble PrecDriver, or Nocturne Atomic Brain. On or other is always on, depending on clean or dirty.  MXR M300 is rarely off too.
  • The last pedal on my board is always a Klon... or a klone these days actually - always on.
  • stickyfiddlestickyfiddle Frets: 27123
    In my old originals band my Timefactor was on pretty much always. I'm a big fan of my one-knob Stratoblaster booster, but now I'm Helix-ed up that won't see so much use.
  • FuengiFuengi Frets: 2850
    Boss RV-6 on the modulation setting with the level and the tone rolled back plus my DOD Looking Glass on low gain also on.
  • Nobels odr1... not always on but I feel like i turn it off rather than on if you know what i mean
  • vizviz Frets: 10700
    edited April 2017
    Boost :)
  • I used to have a sho on all the time, but that sadly had to come off as the muffs with it didn't play nice into the ac15.
    I usually have a boss df-2 on as I have the gain low and it cleans up okay. It's not often I want proper spanking cleans.
  • digitalscreamdigitalscream Frets: 26644
    The AMT F1 - the board is designed so that it effectively takes the place of the preamp section of the amp, so it'd be a bit silly to turn it off.
    <space for hire>
  • professorbenprofessorben Frets: 5105
    edited April 2017
    Fun tho.
    Ugly is the new transparent.
  • SassafrasSassafras Frets: 30294
    The AMT F1 for me too. Most useful pedal  I've ever owned.
    So many features in a tiny box. If I'm playing through an amp I can't get on with, I switch on the F1 and suddenly all is well in the world.
  • JohnnysevenJohnnyseven Frets: 908
    My Diamond Compressor is always on too.
    My trading feedback can be seen here - http://www.thefretboard.co.uk/discussion/58242/
  • TeetonetalTeetonetal Frets: 7807
    None. My amp doesn't need the help ;)
    Mine either.
    I do tho, so my Loop Switcher is always on.
  • GassageGassage Frets: 30928
    My Cornish TES; even when the Delay is off the output buffer is on and everything goes through it to the amp switcher, it's not in a loop precisely so I can use the buffer.
  • lasermonkeylasermonkey Frets: 1940
    edited April 2017
    On my bass board, a DIY Baja opto-limiter and Catalinbread SFT are always on. The SFT is normally used to add some warmth to my Trace amp, but I use it to add a bit of crunch when needed.
     On my guitar board, it depends. If I'm playing swirly guitar music (which is most of the time), then my CE-3, Echo Park and RV-7 will be permanently on.
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • VoxmanVoxman Frets: 4725
    Surely this depends on the type of music you play.  I play mainly classic rock & blues & its only when playing certain songs that I'll use a compressor perhaps with modulation e.g. songs like 'Every breath you take', or 'Run to you', or if I'm playing something jazzy.  But I'd never just leave a compressor on as per the OP - For Thin Lizzy, AC/DC, Free, Bad Company, Cream, Zep etc, I want the tone to stay 'classic rock' raunchy.
  • tone1tone1 Frets: 5171
    Reverb on my Benado Adverb.. :)
  • hotpickupshotpickups Frets: 1822
    edited April 2017
    Compressor is an always on pedal on my board . It's a very versatile one though that I can tweak and adjust the blend etc
  • ToneControlToneControl Frets: 11937
    edited April 2017
    Great question
    for me: TC Electronics Flashback x4
    I almost always play with just a little delay, and nothing else at all
    Like Gearmandude says, Reverb sucks
    i.e. it sucks tone
    when you want it as an effect, it's great: Big sky etc
    I love my Cali76 compact Deluxe, but would not want all the time
