During power up does it briefly display version 2.20?
Ive got the rest - the darkglass models and the new bass amps etc
**But back up your presets first**
So it should have already been there before the update to v2.20. But one would expect 2.20 to contain everything, so I'm not sure what's going on. Perhaps best to ask on the Line 6 forum.
I was getting good results with a random Taylor IR I downloaded free, so I thought I'd try the 3 Sigma Taylor 610E IRs. They come with different versions designed to work in different scenarios. This is what you get:
The Acoustic/Piezo and Acoustic/Soundhole work OK but I can't get a decent sound out of the Electric IRs. When I say "Decent sound", I mean I barely get any output at all. It's like I'm doing something wrong. But I'm loading and using them in exactly the same way as the others.
Has anyone else tried them and got them to work?
R.
Eqd Speaker Cranker clone
I presume you are actually *using* an electric guitar pickup with the electric IR ?
If it's just a level thing what does turning the output level on the IR block do?
I'll have a try with mine tomorrow using an electric guitar and the electric IR (I have the Hummingbird one)
Just for curiosity really.
Now I have a test patch with my usual brewtal boosted rectifier amp settings, but with 8 snapshots with 4 IRs and 4 internal cab sims to flip between.
Amazing how different they can sound.
What is the difference between 1024 and 2048 IRs? I've loaded the free ownhammer 4x12 ones at 2048, but I don't know if I did the right thing, or if I'm just using up DSP
Yeah, I'm using an electric guitar.
It seems like more than a level thing - I'm hardly getting anything, and there is all HF. The piezo sounds louder at -18db than the electric at +6!
R.
Helix IRs are (or get converted to if they are not) fixed 48kHz so the samples figure dictates duration of the IR
Threads I've seen suggest that people cannot tell the difference for cab IRs
Exactly the same with the Gibson J15 set, so I suspect I'm either not doing something right or misunderstanding what the Electric IRs are supposed to do?
R.
Tried the neck pickup?
