Boss GT-100 Output Select
FaffFaff Frets: 29
Dunno if I'm going mad, this has me a bit perplexed.
I have had at GT100 for around 6 months and have discovered the following to do with the System / Output Select.
As it is in the System menu, I have always assumed it is a global setting applying to all patches. Seems the right way to go I think.
When I do gigs with a house amp in place, I try a few outputs - sometimes JC-100 or Stack or into the power loops I use the Return versions.
My patches are all ready setup and this is just to tune to the house amp.
However, I have just found to my surprise that the output amp setting is saved with each patch. So I have ended up with different patches with different outputs selected. This makes for hassle when I turn up and then need to change the output for each patch and save it there and then.
Surely, this should be a global setting so that you set it once and it applies to all patches? In fact, I can't believe that I have only just noticed this and am sure something has changed.
Does everyone else's work like this?
Guitarist for...  HEY PIXIES - The UK's most gigantic PIXIES tribute band
http://www.facebook.com/heypixies
"We don't actually own any of this gear - we're just looking after it for the next Fretboarder."
  • ICBMICBM Frets: 72415
    I don't have a GT-100, but if it's like some of the other recent Boss units you can select it either way. It sounds like you've got it set to 'Patch' rather than 'Global'.
  • longilongi Frets: 95
    edited April 2017
    It might be set up for a patch save function rather than a global setting. I haven't found a patch select-able setting for the outputs on my GT-100 but then I haven't looked. Boss have added a bunch of system wide functions through various updates so it wouldn't surprise me.
  • FaffFaff Frets: 29
    Thanks.
    After much angst for ages, of course I found the setting pretty soon after my posting.
    There is a setting to make the output per patch or global.
    It's in System / Preferences.  Pretty obvious really.
    I swear I never changed it! :)
    Ahh good to know. Glad you got sorted.
    Till I saw this thread is thought it was ONLY a "global" setting. But I prefer it as "flat across the board" ;-)
