disconnecting LP tone pots
The tone pots in my LP are broke. To disconnect them from the circuit it looks like I'd just need to clip the cap' out, right?
would I need to put any earth connections anywhere else?
  • prowlaprowla Frets: 4931
    You can disconnect the +ve wire (coming from pickup or volume control); that way no signal will get to them.
    (P.S. Put some tape over the wire ends.)
  • ICBMICBM Frets: 72471
    Just cut the cap leads at the volume pot end. (Or unsolder them, if you want to do a clean job and make it easier to refit them later, if that matters.)
    You don't need to connect or disconnect anything else, the ground connections don't matter.
  • sgosdensgosden Frets: 1994
    That's what I wanted to hear, cheers guys.
    Will desolder the cap and tape it up until I get round to ordering new pots.
    edited April 2017
    It'll sound a little brighter and louder without the tone pots connected.  If you like this then order no load tone pots - they're out of the circuit on 10 and operate as normal as you turn them down.  I tend to fit these to all my instruments these days, sometimes the extra brightness is helpful.
    edited April 2017
    That might be what is installed now? but they're both fried. (It's someone elses project guitar I picked up on a price to good to turn down).
    currently neck tone is muddy smush through whole range, bridge tone is muddy from 1-10, but appears to click out the circuit at 0.
    The main goal for me here is to have a usable neck pup.
  • SteveRobinsonSteveRobinson Frets: 7041
    Is the cavity shielded? The problem might just be a short to earth.
    possibly, I guess the less lazy thing for me to do would be take everything out, test it and reinstall what's working...
