Line 6 Helix
1217218220222223427
  • ChuckManualChuckManual Frets: 692
     :o
    Not much of the gear, even less idea.
  • TeetonetalTeetonetal Frets: 7817
    I was mucking about with the 3 note generator last night. How much fun is that! Really hoping line 6 get good response to it and develop the synth side more.
    We have a few songs in the band where a little synth pad would really work and triggering chords via the feet would be awesome.
  • SporkySporky Frets: 28771
    Anyone else tried putting a patch lead across a send and return pair, then using them to create feedback loops in the Helix?
    You have to be very careful with levels, but it does create some interesting sounds. Next I might try splitting the paths so that the feedback loop gets processed separately. Delay and wah on just the feedback loop is an intriguing idea.
    @timmyo has started a very interesting thread about triggering via an iPad app
  • POLL: how many Helix Floor (or LT) guys aren't using eithe one or more external Exp pedals?
    And do you find they get much use?
    I use 2
    cant work without them
    1 for volume boost (0-7db) the other for modulation depth or delay mix (or both)
  • Cabicular said:
    I use 2
    Do you find the need to adjust delay mix or mod depth on the fly mid performance or is it for specific effects on specific parts of songs?
  • TimmyOTimmyO Frets: 7581
    Frank Ritchotte from Line 6 is the guest on this podcast this week :  http://www.therockerdadpodcast.com/e/the-rocker-dad-podcast-episode-8-frank-ritchotte/ - some chat about Helix
    Red ones are better.
    Cabicular said:
    I use 2
    I mainly do it for the delay level
    I do it quite a lot. Sometimes for the finishing stab I'll rock it right up
    or for atmospheric whammy dives
  • kjdowdkjdowd Frets: 852
    Cabicular said:
    I use 2
    The volume boost on an expression pedal is a great tip. Have nicked this and use it in all my patches. Beauty of doing it with a modeller is that you can get a genuine and reliable (and variable) volume boost for solos, depending on where you put it, of course.
  • LoFiLoFi Frets: 534
    After a few hours playing with it (I've had a busy week), I noticed a very feint artefact that sounded like a very slightly-delayed octave below. Tried several different guitars, patches (inc. stripping them down to barebones), googling to find out if I was doing something wrong before I realized the mixer I'm running it through had an octave effect with a tiny bit of the main signal fed to it... never been so glad to find something was user error...
    5reaction image LOL 1reaction image Wow! 0reaction image Wisdom
    kjdowd said:
    Cabicular said:
    I use 2
    I put it on the output block
  • John_AJohn_A Frets: 3775
    Use mine as a delay mx 90% of the time I just leave my delay on and add more for the twiddly bits and roll it off when playing chords, use a Wah on a few songs and volume swells occasionally, haven't dabbled with whammy stuff, but should do I suppos
    Rather than just have it adjust output volume, why not have it control a number of parameters to morph whatever best suits the boosted sound (eq shift, effect mix, compression etc) ?
  • ChuckManual said: Guitar > Helix pre-amp/overdrive/distortion models > Both amps front ends > Amps FX loops Send > Helix time-based effects > Amps FX loops Return > (power amp, speakers, etc, etc...)
    There's already a template for using Helix in 4CM with two amps: 8 TEMPLATES > 02B 7-Cable Method. Footswitches 2 and 3 toggle between Helix's preamp models and either/both of your real amps' preamp sections.
    Chief Product Design Architect, Yamaha Guitar Group | Line 6 | Ampeg
    That's a good shout. I always fancied having an amp that turn up the mids as you turned up the gain. Guess I can already do that in Helix!
  • So, just to clear things up, whats the model of Expression pedal that works properly heel-to-toe and with the switch? I've read a lot about exp. pedals that sound weird at the heel position and switches dont work..
    Only reason is, I'd be fine with the built in one for intermittent use, like volume or whammy, but I use wah in practically 90% of my solos, and I'm left footed which makes the movement to use my left foot on it a little awkward...
  • markblackmarkblack Frets: 1591
    So broad question I know but -
    I'm insanely stuck between Kemper or Helix. My main reason being, I only play at home, most likely only through headphones as well...
    I've always been more into FX creativity than into amps, I usually just find an amp that sounds nice clean and dump pedals in front of it but, seeing as I only play at home now, I dont want a huge board and an amp.
    Someone talk me into a Helix, I know i'll like it more because of the focus on FX and amps, as opposed to just amps really in the Kemper
    *DILEMMA*
    EDIT - This is fucking sick!
    Drew_TNBD said:
    Helix doing some cool clean tones and some nuts delay oscillation craziness:
    https://www.dropbox.com/s/213lj38bkbin0uv/Shake The Creeper_Vox.mp3?dl=0
    (New TNBD song idea!)
    I was in exactly the same place. Was about to buy a kemper. Tried a Helix and haven't looked back. If you're into FX IMO the Helix is great - you can kind of do anything. I dropped a few £ on a pair of Sennheiser HD 600's
    Best guitar purchase I've made. I play more and more. Yes it's pricey for home use - but the LT might answer that.
    All that said I'm sure the Kemper is very good. Just the way you use the Helix is so clever and intuitive.
    Interesting! I have bought a Helix, waiting for it to arrive.
    Another question - how are the HD600's with it? Do they give like a nice actual-amp-sounding sound? They are the headphones I'd been thinking of getting for using with it as I'd read everywhere theyre nice, would be good to get an idea from someone on here thats used them!
    The Full floor version doesn't support toe switches on the ext pedals just the built in one.
    Having said that I really think your best option is to continue to use your favourite wah and use the onboard exp for delay depth or amp blend or solo boost (or all three....)
    The onboard pedal has a toe switch that means you can switch the wah on and off (its basically two expression pedals in one)
    Thats a great idea but there are some issues that have been pointed out here. The main one is that to engage the wah you have to push the pedal forward to engage the toe switch. Meaning if you have the pedal doing anything else it will be 100% every time you use the wah
    I would keep a separate wah if it is that important to you
