FS: AMT Power Eater 15W reactive load, £70 delivered
One for you recording folk here. This is the little brother to AMT's 120W reactive load, 8 ohm only. Plug your amp in, and record direct to your interface (then you just need to apply a cab sim of some sort, eg impulses). This one has a line output and two cab ouputs - one which sends all the power to your cab, and one which only sends 10% of the power. You could actually use it as a fixed-volume attenuator, should you fancy.
It's worth noting that I've used this with my 50W Jet City, and it worked just fine. You just have to keep the volume low enough to stay out of the red on the volume LEDs.
(mouse not for sale, it's just there for scale)
£70 delivered.
<space for hire>
