How high do you wear your guitar?
  • carloscarlos Frets: 3451
    skunkwerx said:
    ummm... Am I doing it wrong then?
    photo explorer_zps54btinh9jpg
    You got it the wrong way around
    I sit down, put guitar on my lap, than adjust strap until it's pretty much the same.
  • SkippedSkipped Frets: 2371
    Not too high.
    I used SGs for a long time. The strap was marked (with a Sharpie) at either side of the buckle. If the guitar felt "wrong" I would know that the strap length had moved a quarter of an inch even before I looked at the buckle.
    I think Mark King would have had a different career, may not have been famous, may have been a jazz musician, if adjustable guitar straps had been available on the Isle of  Wight. That is how important strap length is.
    Of course.....one advantage is that "Ex Mark King" bass guitars are more identifiable thanks to  the teeth marks on the upper horn.
  • bbill335bbill335 Frets: 1381
    Quite high, compared to other people I think. My couch strap is as short as it will go and I wish I could get it another inch or so shorter.
  • VoxmanVoxman Frets: 4725
    This high for me:
  • ESBlondeESBlonde Frets: 3593
    Also wear the 335 higher up but generally all the guitars are higher than I would have worn then 30 years ago. Short grey hair on a middle aged gut means cool is not an issue.
    Each guitar has its own strap with Dunlop straps so quick length changes are a no no.
  • DanjiDanji Frets: 225
    I'm between Dunnery and Slash! But I have a lot of respect to those that wear 'em low!
    edited April 2017
    I used to swing them at Bolan height, but it gets higher
  • stratman3142stratman3142 Frets: 2198
    About Robben Ford height, which I suppose is quite high.
    It's not a competition.
  • richardhomerrichardhomer Frets: 24833
    But not as high as Roy Buchanan....
  • HAL9000HAL9000 Frets: 9689
    edited April 2017
    If you wear your guitar at chest height you play it with heart.
    If you wear your guitar at stomach height you play with guts.
    If you play it any lower you play it with cajones.
  • WolfetoneWolfetone Frets: 1479
    All the same height, all the same height as they'd be sat down with the guitar on my fretting hand leg with my foot on a footrest (always wear the strap anyway).
    Beat me to it. I set the guitar at the height that I would be sitting.
    But chairs are different heights
  • djspecialistdjspecialist Frets: 908
    @Voxman nice chunky tone you have there.  Which amp / pedals are you using?
    Trading feedback | FS: Nothing right now
    JM build | Pedalboard plans
    edited May 2017
    Bridge a bit below belt buckle height.  Apparently I angle the neck quite steeply.
    Charidee T-shirt optional, for extra rock-n-roll street cred.
  • axisusaxisus Frets: 28339
    This thread would be better if we all posted pix! we should have a 'post your guitar playing height' picture thread.
    High looks naff to me and Slash level is impractical, so a tad low for me but nothing too mad. It's higher when I play sitting down though. To be honest I do have phases of higher or lower sometimes.
  • DominicDominic Frets: 16109
    Difficult one ....I have those platted leather buttons on most of my cardigans which tend to get in the way ..........
    Your pic isn't showing ;)
  • ChristopheChristophe Frets: 62
    Bit fuzzy as it was from back 'int daaay
    https://i.imgur.com/rQy3UWx.jpg
    axisus said:
    This thread would be better if we all posted pix! we should have a 'post your guitar playing height' picture thread...
    It was quite high up at this gig.
    http://i.imgur.com/DqO2cqw.jpg
