http://www.thefretboard.co.uk/discussion/61134/sarge/p1
Eqd Speaker Cranker clone
Nil Satis Nisi Optimum
Instagram
I also completely forgot all the advice given on this thread and have simply glued with Titebond and clamped. No epoxy, no hairdryer. Left it for 24 hours.
I started stringing it but noticed that the saddle is missing so I need to get one of those before I can bring it up to tension and see how the headstock holds.
Fingers crossed...
If it goes again, I'll remember to use epoxy + hairdryer next time!
R.
It wasn't until I started stringing it that I noticed that the saddle was missing
I've ordered a replacement which will be here tomorrow.
How do I set the correct height? I'm guessing I'll need to put all the strings on and get the neck under tension to correctly measure the string height, then take the strings off again to sand down the bottom of the saddle to lower the strings to the correct height?
R.
