Dual Tremolo?
smudge_ladsmudge_lad Frets: 669
Hi guys,
Looking to see what my options are here - I really need two different settings (speed only) for my current song list.
I see that JHS make a pedal that does exactly this, or there's also one from Rockett pedals that has two completely separate tremolo's, however for the same/less money I could get a used Flint and have a favourite switch. I'll then also have the benefit of the awesome reverb and trem/verb combination of this pedal, even though I'm already sorted for reverb
  • colourofsoundcolourofsound Frets: 395
    Black Cat Mini Trem
    Stone Deaf Tremotron
    Fulltone Supa Trem
    Chase Bliss Gravitas
  • smudge_ladsmudge_lad Frets: 669
    Black Cat Mini Trem
    Fulltone Supa Trem
    I think I would struggle with the Black Cat and Supa Trem as the speeds I need to use are not exactly half/double speed :(
    I'm all about trying to avoid twiddling during a set, because I always forget to do it
    I think the Tremotron and Gravitas offer far too much options for the very little I use the effect, although would love to have a Gravitas at some point
  • EricTheWearyEricTheWeary Frets: 16297
    There are a few tremolos with tap ( like the T Rex)and some with external tap ( like the Source Audio) if it's only the speed that's the issue.
  • vasselmeyervasselmeyer Frets: 3672
    Diamond TRM-1. An awesome pedal with tap.
  • UnclePsychosisUnclePsychosis Frets: 12923
    The Zoom CDR70 or whatever its called has a dual tremolo on it.
    Line6 M5 and an expression pedal
  • CookiemonsterCookiemonster Frets: 886
    On the zoom you could set two presets up easily and toggle between  them. Cheap as well.
    Instagram is Rocknrollismyescape -
    FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
  • dindudedindude Frets: 8539
    2 x TR2's
    The Empress Tremolo has a "two speed" setting actually (or at least V1 of the pedal does---don't know about V2). You can then switch between the two with a single button press.
  • VJIvesVJIves Frets: 466
    The Twin Stags by Dwarfcraft is good fun but it has a CV input and no tap which is a shame.
  • TeetonetalTeetonetal Frets: 7809
    The josh smith one from jrad is two independent tremolo. So the fun is in chaining them together, not in having 2 presets.
  • HattigolHattigol Frets: 8189
    I have one of these - Rockett Josh Smith Dual Trem
    https://reverb.com/uk/p/j-rockett-josh-smith-dual-tremolo
    They're great. You can have one side with a really slight trem and the other deeper. Plus there's a lovely controllable boost on it which is really useable. Got it as a clearance one from Guitar Guitar. Wasn't a crazy price.
    "Anybody can play. The note is only 20%. The attitude of the motherf*cker who plays it is  80%" - Miles Davis
    edited June 2018
    @Teetonetal ;pipped me to it....
    Thanks guys, but not really sure how this thread has been revived/bumped to the top from last May.
    I ended up going with the Flint :)
  • stickyfiddlestickyfiddle Frets: 27133
    I assume it's because I also started a thread on Dual Tremolos and someone got confused!
    I'm thinking it may have been me. But hey, ita great pedal!
