Tweed Bassman speaker wiring puzzle!
Hi, I have a Tweed bassman clone that is wired with two pairs of speakers going into two separate mini jacks into the amp.
I just read that normally the speakers are connected positive to positive. I noticed that mine were pos to neg so changed them round but they definitely sounded out of phase then. So obviously mine are in phase pos to neg, is that possible?
  • ICBMICBM Frets: 72490
    Are they in series? ie amp > speaker 1 > speaker 2 > amp, three wires not four. If so then positive to negative is correct.
    Mini-jacks sounds like a bad idea...
  • liftmanliftman Frets: 61
    Thanks for the reply. Yes, each pair has a wire from the jack going to the pos of one and neg of the other. Then another wire attaches the other pos and neg.
    Would two pairs in series like this react differently to the usual parallel wiring ( and therefore sound different)?
    I guess they are mini jacks, the outer casing is only a bit smaller than guitar jack but the stem is definitely thinner.
    Slightly, yes. But it's not easy to compare the two or to change it, since the reason they're done like that will be to work with an 8-ohm output transformer. Original Bassmans have all the speakers in parallel, with a 2-ohm transformer.
    If they're 3.5mm mini-jacks I would replace them with proper jacks, they're a bit flimsy for speaker connections.
