http://i44.photobucket.com/albums/f21/Lonestar83/Mobile Uploads/BB3E4AEA-B484-4CDB-93E2-7714FD317306_zpsnpa3nrbs.jpg
• Youtube - https://www.youtube.com/@Goldeneraguitars
http://i44.photobucket.com/albums/f21/Lonestar83/Mobile Uploads/32105E5E-EEF3-499C-A0EF-842A8A90B2FE_zpssiqll1ae.jpg
Im going to have to research the cabs again. I had done this a while back but marshalls history was all over the place with regards to what components were used and when. As you can see.... a set of 3-1 speakers.. interesting.
But wait.. what's that?
http://i44.photobucket.com/albums/f21/Lonestar83/Mobile Uploads/D99F6946-6C30-472D-91E2-CFF691F83830_zpsq6fvj6yl.jpg
Is it possible that Jim signed this?? It matches up to others that I've found online. AMAZING if true!
Check the speaker codes and you'll see if they're all the same age or not. It could be a factory "we used what we had" situation or the G12M could be a replacement.
I have to fix the tolex underneath the cab so I'll check it tomorrow. I'm hoping it's all stock, it would be pretty cool.
From an age where Jim himself would go down to the shop floor and do the dirty work. Extra special.
Tbh the cab looks great in real life. Plenty of vintage vibe
The odd one is your greenback is from 31st August 1971!!! so someone has blown the speaker and replaced it with an old GB, as to when who knows?
Bet it sounds great cranked, although I think I'd replace the GB with a 30watter 55hz. It would probably help take the strain off the 25w GB which at that age can be prone to cone rub and glue's coming away.
My band, Red For Dissent
I don't regret selling the amp
