Barre chord thumb position
Over the neck or at the back in the middle?
  • octatonicoctatonic Frets: 33805
    There are a few schools of thought- for me and based on fairly extensive experimentation this is the best way for musical facility and hand health:
    For chords and single note lines without string bending- behind the neck, in line with your middle finger.
    When bending strings hook it over the top and bend with your wrist, not your fingers.
  • thomasross20thomasross20 Frets: 4437
    Agree!
    It's just I've always done barre chords with finger in the middle of the neck.. but I tried with the thumb over the top the other day and can see how your finger has a bit more grip and acts more like a capo, but also found it needs more overall hand movement and was harder to do things with the other fingers.
    So/// behind the neck is ok.
  • DanjiDanji Frets: 225
    Behind the neck for the most part for me.  But now I'm thinking about it, I don't play that many barre chords.
  • Paul_LPaul_L Frets: 52
    I think it depends on what I am doing. If I need to use my little finger to play a few individual notes I tend to drop my wrist down and my thumb moves automatically, otherwise it is wrapped around the neck so I can mute or push down on the E and A strings if need be.
    Maintained it for 20 years. This old guitar's had 17 new necks and 14 new bodies in its time.
  • RolandRoland Frets: 8731
    edited May 2017
    Conversely I use barre or partial barre chords most of the time. Thumb behind or over the top depends on what type of music I'm playing, and how loud I want the bass notes to be compared with the rest of the chord. It also depends on which guitar. Small radius fretboards favour thumb over, and flatter boards favour thumb behind. Then there are chords inversions like Amaj7 5 x 7 6 5 4 which can't be played any other way
    For A maj7, I'd most likely imply it.
    Three notes at the most
    X 4 6 X 5 X
  • EvoEvo Frets: 308
    X07654
    Tadaa!
    re:Thumb - straight up the neck - classical technique.  As a yoof I didn't and have arthritis in my thumb as a result. I prefer not to use barre chords if I can.
    On the topic of barre chords - they suck for anything other than solo/singalong performers - especially amplified, they fill out the mids in a really unattractive way. I'm trying to coach my other guitarist, if he can't be bothered to learn non-barre fingerings, then to only play the top 4 strings to avoid the dreadful din they make.  Compounded if you add distortion IMHO - yuck !
    Feedback
    Evo said:
    X07654
    Tadaa!
    Yep, but it's not transposable. One of our songs has Dmaj7 played as 10 x 12 11 10 9
    That's one of the advantages of thumb-over. It's easier to mute the lower strings selectively
    Roland said:
    Evo said:
    X07654
    Tadaa!
    You don't need the bass D at the 10th fret, that's the bass player's job.
    You could equally play   x 5 7 6 7 x - that's also Dmaj 7th  (Though I prefer   x x 4 4 5 5 - Dmaj6 if it's a generic "majorish" sound you want)
    Feedback
    I only started the thread as despite playing for something like 16 years (!?) I saw a video the other day with some guy saying the "proper" way to do it was with the thumb over the neck - this video may not be the absolute truth... but it got me thinking.
    I tried it and in some situations it does feel ok.
    It's sometimes tricky getting every string to ring when barring - and yes, I rolled my index finger somewhat to the left.
  • vizviz Frets: 10700
    edited May 2017
    Jalapeno said:
    Roland said:
    Evo said:
    X07654
    Tadaa!
    If I wasn't able to play it based off the A string (x5767x for Dmaj7), I'd normally play Amaj7 either as 577999 or x 12 11 9 9 9 for a fully voiced chord, or just barre it at an angle so you get 5x7654, with the first finger playing the 5th fret at the bottom string and the 4th fret at the top string. This is what I do in the F#maj7 in Ipanema, or I just play the top 4 strings. I don't think I ever use my thumb.
  • mike_lmike_l Frets: 5700
    Depends on the part
    some thing like
    577655
    I'd have my thumb in the middle of the neck's back,
    For the Hendrix/Townshend way
    5x7655
    I'd have my thumb over the top and fretting the low E string
    For something like
    xx7655
    it would depend on what was being played before/after, but mostly it's thumb behind the neck.
  • Old_SwannerOld_Swanner Frets: 24
    edited May 2017
    Can you get the chord to work without your thumb on at all?  This means pulling the chord into the fretboard using the power of your fretting arm, while counterbalancing with your strumming arm.
    If you can't get the notes to sound the way you want, then this is highlighting problems with your barre.  Once you've worked out how to get things sounding good with no thumb involved, you can then add the thumb back for stability and maybe a little extra grip.  This process will show you the best position for your thumb.
    When other sites and teachers leave you frustrated: https://www.taplature.com/ 100% Unique, 100% Effective, 100% Free!
    Just FYI I'm not actually fretting notes with my thumb...
    Why not? It's there!  ;)
  • Danny1969Danny1969 Frets: 10429
    I do most stuff with Thumb over and thumb actually fretting the bass notes ... some stuff that's a big stretch needs thumb in the middle though.....
    I do feel there's more control and power with thumb over for most things
  • ICBMICBM Frets: 72483
    You'd hate my playing then :) … I use a lot of full six-string barre chords, often with moderate distortion. It gives a huge sound in a one-guitar band.
    It's also true that I like high-powered scooped-sounding amps compared to a lot of players though - and even then I often tend to take out the mids almost completely. Heresy, I know  - "the guitar is a midrange instrument' and and all that crap - but it works for me. Maybe that's why…
    Where do I put my thumb - wherever it's convenient. The higher up the neck you're playing, the more it has to be behind the neck.
  • EvoEvo Frets: 308
    Another nice Dmaj7 voicing...
    XX4635
