Pedal Repairs Peterborough Area
professorbenprofessorben Frets: 5105
Hi all, just had an SD-1 with a monteallum mod that's taken a knock in transit, little dpdt switch is buggered.
Anyone know simeone in the area to fix this?
I might do it my self but I'm on call again this week and spare time is just a distant memory recently.
  • longshinslongshins Frets: 246
    Bit of a way off but there's Eli Abbott in Wellingborough
  • professorbenprofessorben Frets: 5105
    Oh, I have a store in Welli I look after.
  • CorvusCorvus Frets: 2926
    Brian Swatton, his info's in the amp tech thread, or brianswatton.co.uk
    Yeah I tried him, but looking at a 2-3 week turnaround.
  • SassafrasSassafras Frets: 30294
    Same thing happened to mine. The switch became temperamental. I cured it by stuffing a bit of card under it between the PCB.
    Not a very professional cure but it's working fine.
    Yeah it's got a bit of tape ensuring no grounding out, but the actual switch has taken a kicking.
  • mike_lmike_l Frets: 5700
    There's Chris Newman in St. Ives. He also does amp repairs.
  • GavRichListGavRichList Frets: 7173
    There's a couple in Leicester if you deem that "in the area"! Howard Smith has done a couple of mine, and John Southgate is highly recommended too. The latter saw to my AC30, and does pedals too.
    He's the best bet then, doesn't charge much and isn't a twat.
    Sounds like a great recommendation.
    That's the strap line on his business cards...
    Honest. I like it.
