So, after this pedal was suggested to me by @EricTheWeary while I was looking for a dual delay option, I did some digging and while there wasn't a massive amount of info/demo video's available, I liked what I saw/heard and decided to give it a punt.
It arrived yesterday, and I've only had a very small play around with it at bedroom levels, but I'm really impressed with it so far.
It has two basic modes - simple "play" mode where all 3 pedals work as if they were independent stomp boxes, or a saved "preset" mode where the pedal will store all current settings and assign to a patch.
The delay's sound great - albeit there are some really crazy settings that I can't see me ever using. I haven't really used reverb too much, but this also sounds pretty good to me - the independent shimmer control that can be applied to any of the reverbs is a brilliant option.
Another great feature is that you can freeze any of the effects by holding down the footswitch while the pedal is on.
Will give it a good run through at band rehearsal tonight and see how it stands up with some overdrive/distortion involved!
http://i86.photobucket.com/albums/k100/keir_smith/8243F3F3-C2DA-42A9-9610-6B7AC9076E50.jpg
http://i86.photobucket.com/albums/k100/keir_smith/E4390CE9-B132-4FE1-8F0E-E6998E7D58E8.jpg
http://i86.photobucket.com/albums/k100/keir_smith/6868F98E-C6C6-499D-9E36-D82A125BA93E.jpg
Yes, I've still yet to see a decent video. The only properly made one was the Andertons one but they clearly hadn't read the manual, had no idea of anything interesting you can do with a delay and added a shed load of reverb so you couldn't hear things clearly anyway.
Without rewatching them I think it's this one that explains what it can do, although not the best sound and, IIRC, the Mooer demonstrator says something to the effect that he doesn't use complex delays (FFS!).
I'll be interested to know how you get on, I have two delays and a reverb on my board and this would not just tidy that up but give me some new possibilities.
Instagram is Rocknrollismyescape -
FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
I was a TAD reluctant to go for it, as I haven't tried any other Mooer pedals before, but I was impressed with the video's I did see so I thought I'd give it a try. Still have 60 day return policy etc if it turns out it's not for me.
So far it seems perfect - great capabilities minus the complexity of something like the DD-500
This is disappointing since I only bought it on Sunday.......£38 cheaper. F*ckers!
I guess you could try contacting Bax but these things seem to fluctuate a lot.
I shall go and do some actual work now, that would be less harmful...
Not to worry mate, not your fault
Bax prices go up and down a lot . I was watching a reflex for a while and in two weeks it went from 169 to 215 and back about 8 times...
Might be the best demo. Amazing amount of flexibility.
