Did you tape it off?
Or use a wooden block to drill through?
Drill barely engaged before it shattered ....
Feedback
I use offcuts of ply wood or mdf.
This is where a pillar drill comes into its own though- because you can clamp everything down.
Were you using a HSS or brad point bit?
My jig-saw was creating small chips, but when the supporting part got thin (ie. when I got close to an edge) - that wanted to shatter too and did - but I just got lucky with the outline I think. Conversely I had to make an indent for the floating pickup - that was a doddle with the Dremmel and a grinding stone - perfect !
2mm Acetate/Cellulose is bendier so should be more tolerant.
Feedback
Helps if you works slowly with acrylic too- once a bit grabs that is it.
You can get special plexiglass drill bits which eliminate the need for a pilot hole.
I've always used brad point bits and a guide block and never had a problem.
I've got a spare laminate sheet (4 ply) tortoise, then white/black/white - not sure what it is made of tbh - might experiment a bit more over the weekend with metal/wood jig-saw blades, and drill bits & blocks
Feedback
In general, for plastics, use very sharp cutters - good quality and as good as brand new, preferably reserved for plastics (or at least soft materials - don't use drill bits that are also used on metals). Relatively slow rotation speed and feed rate. Let the sharpness do the work - the rotation speed and feed rate should be such that thin slivers of the stuff is removed with no effort.
And, as mentioned, put a sacrificial support block/sheet underneath it.
Nomad
Feedback
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
