Les Pauls: TOM & Stoptail vs Wraparound bridges
guitargeek62guitargeek62 Frets: 4142
I'm looking to get an LP-type built and I'm currently leaning towards using a wraparound bridge based on my preference for PRS and Juniors in the past.
What do you think I'd be gaining/losing out on by going for the wraparound over the TOM & stoptail route? At a later date I may even add a bigsby too...
  • CollingsCollings Frets: 411
    With a wraparound you maybe loosing some adjustability dependent upon which wraparound you go for.
    In terms of tonevi tend to find the wrap arounds have more "twang".
    edited May 2017
    You can get a greater range of feel in terms of setups on a TOM in my experience. Break angle definitely makes a difference to playing feel (especially bending), and with a TOM you'll be able to try more angles.
    With an adjustable wrap you can use the intonation screws on the posts to do this to a lesser extent (further away from the posts plays tighter), but if you go for a bridge with fixed intonation like the standard PRS wrap you'll be stuck with what intonates.
    In terms of tone I don't think I've played enough otherwise directly comparable guitars to make a choice... but in terms of setups I'd go TOM 1st, adjustable wrap 2nd, non adjustable wrap 3rd. YMMV!
    If you're building from scratch I'd consider locking posts whatever you choose. They're a nice to have, rather than an essential, but worth it IMO.
  • ICBMICBM Frets: 72447
    Fitting a Bigsby to a guitar with a wraparound requires more major work than to one with a tune-o-matic, if that makes the decision easier.
  • TeyeplayerTeyeplayer Frets: 3223
    edited May 2017
    Listen to that...the man knows his stuff. The decision should therefore be made. :)
    I should probably add, it's not a guitar without a bigsby! ;)
  • WhitecatWhitecat Frets: 5431
    On any guitar style I've seen where both have been available/possible in some form or another, to me, the TOM + stop tail route pushes out more midrange and sounds a little girthier, whereas a one-piece bridge, adjustable or not, seems to be more about the preservation of harmonics and high-end. So if you want that fat vintage Les Paul sound, the 2-piece rig is the way to go. A one-piece will sound a little more modern with more sparkle.
    Which one is *better* to me depends on the guitar and the pickups and what I want to do with it, but obviously YMMV.
  • guitargeek62guitargeek62 Frets: 4142
    Fair points on being able to affect the string tension - it's been so long since I've had a TOM-equipped guitar that I'd forgotten about that extra!
    Might as well go for something a little different to what I already have too - hopefully once it's built it'll save me pining for a 594 / 594 SingleCut at some point.
  • ExorcistExorcist Frets: 604
    Given the choice I prefer a wraparound, my best sounding guitars are all wraparound. That could just be coincidence of course.. Plus I don't feel the need to constantly fiddle with the intonation :)
