Ampeg Diamond Blue series J-20 JET valve amplifier. Stunning and unusual retro style tube amp hand wired point-to-point by Ampeg. No circuit boards here.
http://s1276.photobucket.com/user/jmaster10/library/ampeg
Don't let the size fool you, this thing is loud! The circuit is based closely on the brown face era fender deluxe, but modded to give you plenty of headroom up to about 12 o clock on the volume knob. I tended to use this clean and it rarely got turned up past 10/11 o clock at small/medium size gigs even when not mic'ed. From 12 onwards or with a boost/OD into it you get a beautiful, responsive, bluesy compression/breakup and turn it up to full (only done this once or twice because it is DEAFENING) you get full on crunch. Think Jimmy Page on Led Zep 1, that was all done with cranked small amps and sounds enormous. Takes pedals beautifully. No reverb as it's a very simple design with only volume and tone (which also seems to control gain somewhat) and 'bias vary' (old school fender style) tremolo, controlled by the speed and intensity knobs and included footswitch.
Specs:
1 x 12" alnico speaker
3 12ax7s in the front
2 6v6s in the back
fully valve rectified (5ar4)
comes with original manual and foot switch but no box
Minor cosmetic wear and tear but in good working order. Tubes are a couple of years old but it has seen very little use over this time, hence the sale. A cracking, slightly different amp at a bargain price.
collection from fallowfield area, M14
£400, reasonable offers considered
SOLD
http://www.thefretboard.co.uk/discussion/49023/thefretboard-classifieds-rules-v2-0#latest
And look what they look like inside
http://www.ampeg.com/products/diamondblueguitar/j20/images/wiring_LG.jpg
You need to to post a price though fella or the ad will get deleted.
redrighthand - did I buy this off you? or something else? It is an awesome amp, gutted I have to let it go
