Sporkaster 4
  • SRichSRich Frets: 762
    edited May 2017
    Sporky said:
    I have decided on my next build; it is suitably over-ambitious.
    Great thread........but this teaser is a bit like "Tune in next time folks!"..... ;)
    "There's things I want, there's things I think I want
    There's things I've had, there's things I wanna have"
  • SporkySporky Frets: 28381
    That's the idea.
    More teasering (sic): it'll be a modern take on a long-established design, and I can think of several people who will, initially at least, be quite upset about it.
  • RolandRoland Frets: 8714
    Sporky said:
     ... a modern take on a long-established design, I can think of several people who will, initially at least, be quite upset about it.
    That's the type of guitar which we should be building. There are far too many reproductions of 1950/60s designs, and the world has moved on since then.
    Now there is an assumption...
    The cap-head screws for the pickups have arrived. Let's hope I measured right... these'll give SP4 a nice industrial look.
    Progress!
    Scratchplate trimmed around the neck pocket and screwed in - also used cap head screws for the pickups, pickup switch and control plate.
    http://monkeyfx.co.uk/pictures/builds/SP4/010617 assembly/01 neck pup.jpg
    http://monkeyfx.co.uk/pictures/builds/SP4/010617 assembly/02 bridge pup.jpg
    http://monkeyfx.co.uk/pictures/builds/SP4/010617 assembly/03 control plate.jpg
    And this is the body assembled - wiring still to do, then drill the neck for its mounting screws, mount the tuners and do the nut and we're there. I have tomorrow off and should get most of this done.
    http://monkeyfx.co.uk/pictures/builds/SP4/010617 assembly/04 body.jpg
    Looks great, liking the Allen bolts...
    Yup - very nice touch....
    Ta gents.
    Today I have started wiring. The control plate and one knob needed drilling out so that I can use a no-load tone pot, and I'm not certain about some of the pickup phases so I'm using teeny crimp connectors to make it easy to swap later. Neck is bolted on and the tuners are fitted - with a following wind I'll be done today.
    It's done! Wiring went pretty well, there's just a lot to fit into a Tele control cavity.
    Pickups are an Oil City Scrapyard Dog in the neck and an overwound Nightfighter in the bridge, then the combinations are:
    Neck (series)
    Neck (parallel)
    Neck and bridge (parallel)
    Neck and bridge (series, out of phase)
    Bridge
    Because the Nightfighter is so high output the out-of-phase option isn't all thin and wispy like normal, instead it has a sensible output and a nicely honky sound to it. I am most pleased with this.
    http://www.monkeyfx.co.uk/pictures/builds/SP4/020617 completed/01 sp4 front.jpg
    http://www.monkeyfx.co.uk/pictures/builds/SP4/020617 completed/02 sp4 back.jpg
    Very nice, well done!
    Thank you!
    Full specs (as much as I can remember at least)
    Body is something mahoganyish (2-piece from David Dyke)
    Neck is birdseye maple
    Can't remember what the fretboard is
    25" scale, 12" radius, jumbo fretwire
    Lefty Wilkinson bridge with a set of righty compensated brass saddles
    Oil City pickups - Scrapyard Dog and overwound Night Fighter, 5-way switching
    No-load tone pot
    Axetec mini locking tuners
    DiBond brushed ali scratchplate
    Finish is Chestnut spirit stain and brushed acrylic - very, very thin
  • EricTheWearyEricTheWeary Frets: 16297
    Well, excellent!
    I cant remember if I've commented on this Discussion before but I love a stratele and some further little twists here as well. That looks absolutely great.
  • KDSKDS Frets: 221
    Nice
  • Cor! Looks brilliant. Wow awarded.
    Fanks chaps. I'd put this off for years and it's turned out to be the best guitar I've made - with this and Sporkbasser 1 I just need to build something with a tremolo...
  • SeshSesh Frets: 1843
    Nothing short of awesome. Well done.
    Can't sing, can't dance, can handle a guitar a little.
  • RockerRocker Frets: 4985
    Very nice.  I like the idea of the output jack socket fitted to a Strat jack socket panel at the back of the guitar.  And the colour is great too.
    Nil Satis Nisi Optimum
    I've done that output jack on almost all of the guitars I've made - dead simple, looks clean and it put sthe lead in a useful place to wrap around the strap button. Patent not pending.
  • AustrianJohnAustrianJohn Frets: 1683
    Cool guitar - nice job!
  • boogiemanboogieman Frets: 12383
    Nice work sir. Wish I could get anywhere near that level of woodworking competence.
