Inverter cable confusion
57Deluxe57Deluxe Frets: 7339
edited February 2014 in FX
I have a Soundlab Pedal Power  AC block to power my few pedos which delivers only centre neg polarity. However one pedal I have is Positive centre. I thought a polarity inverter like in the link would do the job but have read all sorts conflicting gen  - any experience??
<Vintage BOSS Upgrades>
  • FazerFazer Frets: 467
    what conflicting info did you read?
    i have used a polarity converter for centre pos pedals and it was fine
  • 57Deluxe57Deluxe Frets: 7339
    one nuggett I was given was:
    "The polarity inverter cable will do the job, but, if the outputs on the power supply aren’t isolated you might find it causes the power supply to short."
  • ICBMICBM Frets: 72418
    That applies to positive *ground* pedals like vintage-style germanium fuzzes.
    Positive-tip jacks on negative ground pedals (which is almost all modern pedals with positive-tip power supplies) will work fine. It's the pedal ground polarity that matters, not the jack polarity.
    It's rare for any pedal not using vintage-type germanium transistors to be positive ground - although I think there may be one EH pedal that is, for some reason (although I could be wrong).
  • MaxiMaxi Frets: 13
    I never bothered with them for that very reason .
    Blackstar HT pedals I can live with but reversed polarity ? no thanks . Only takes one helpful busy body to screw up while your backs turned.
    Flown the nest .
