One trick you may not know..if you're not using the effects loop you can use the effects return level control as a master volume and set the amp on the edge of breakup and use a boost to send it into more drive..... or just max out the volume and master and pull the mid boost out for a lot of drive..It's a very versatile beast, one of my favorites
both really great amps
A few questions ya:
So if not using the effects loop, I can use the level as a master volume. So what happens to the actual master volume on the front when I do this?
When you say pull out the volume and master. Are you talking about the gain and master on the front? Then use the effects loop level as the global master?
The gain control on the Studio Pro doesn't really add that much gain but you can get them to really drive if you play around with the amp as described above...have fun....
The clean sound is pretty awesome too!
Yeah that effect level works great. Dial the gain and master to get the sound. Effect level for the volume.
Very happy so far. Use it at rehearsal next week
