Are there any half decent 12 volt guitar amps around ?!
riffpowersriffpowers Frets: 344
i'm converting my van into a "leisure and pleasure " vehicle .
it'll have a 12 volt leisure battery , so I was wondering if there are any small practice Amos that run on 12 volt that I could install ??!!
anyone know ?!
    Why don't you get a power inverter and then you can get a proper amp in there?
  • riffpowersriffpowers Frets: 344
    I did think of that but I don't know how long I'd get out of it !!
    The Blackstar Fly 3 runs on a 6.5v PSU, you could make a Voltage Divider and run that. Although it uses 6 AA batteries which would supply 9v in total, so you might want to look into that as well.
    If you want something a bit bigger than the Cube Street EX runs on 8 AA Batteries or a 13V PSU (But due to the batteries supplying only 12V, it should run on 12).
  • SassafrasSassafras Frets: 30294
    ZVex nano head will run off a car battery (I think).
