PA Hire and Event Management
I don't think they still make them but the EQD Disaster Transport Jr. is sweet too - well worth a look (it's an analog voiced digital delay BTW). Might be able to find one second hand if they have stopped making them.
EDIT: There's also the Carbon Copy Bright for those that find the normal CC too dark. I haven't had any experience with them though so can't comment any further.
The Seymour Duncan Vapour Trail might be the one to look at if you want more control over the modulation ( the CC has a button but internal trim pots).
If you did fancy some crazy noises the Sinvertek Fluid Time MKii packs a lot in and the DOD Rubberneck hits the shops in July.
My music:- https://soundcloud.com/hubobulous
Memory Man, thank me later.
FS - P90 pickups
FS - Catalinbread Silver Kiss Mark 2 overdrive
The cool thing about the Montavillian is that its compander-less unlike most true analogue delays so it keeps a lot of top end frequencies & is really bright sounding rather than the dark tones a lot of analogue delays have (actually has a 'top-cut' control, to dial off the extra high end if desired!). Basically, the compander circuit is the reason for this in a lot of pedals - it COMPresses the signal going into bbd chips and exPANDs them back out on the other side so tends to lose high frequencies.
Moog MF Delay is also cool for an all analogue delay - you can you an expression pedal to alter the delay length on the fly and get some really cool effects.
Nearly bought one (my board is too full though!) but have a couple of other Moog pedals and they're solidly built and sound great
After a fair bit of listening I found a demo for the Alexander pedals Amnesia and was wow'd, beautiful warm full range repeats. I have one on order and it should arrive tomorrow with luck.
