Please Any banjo experts on here? Thn x
stuagustuagu Frets: 334
Sorry if wrong section.  so, got given a banjo by someone and my daughter wants to learn. So, cleaned it up, and i Ordered some fresh strings but... they arent long enough . Two of them wont reach ( well not enough to get it round the tuner properly ) the tuning keys.
Im wondering if theyre are longer neck banjos that are tuned different and have a different scale and string length hence needing differing strings?
Thanx in advance for any help .
Gu
  • SassafrasSassafras Frets: 30301
    There are different sized banjos, just like guitars come in different sizes.
    Did you maybe buy tenor banjo strings?
    Is it a 4 or 5 stringer?
  • stuagustuagu Frets: 334
    Thna for reply bud, Its 5 string and its quite big, ... i mean its the same length as astandard telecaster.
    Just ordered 5 string banjo strings... perhaps its one of these " long neck " banjos? But then i couldnt find long neck banjo strings?
  • HAL9000HAL9000 Frets: 9702
  • ICBMICBM Frets: 72487
    A banjo player I used to work with had a long-neck banjo which he had this problem with - he would use single guitar strings and cut the ball end out with a pair of heavy wire-cutters. You have to get it at just the right angle so you don't cut through the string as well...
  • english_bobenglish_bob Frets: 5160
    That's God's way of telling you not to play the banjo.
  • RandallFlaggRandallFlagg Frets: 13946
    I've twanged a few banjos in my time if you get my drift. :-)
    Ewwwww..!
    Sassafras said:
    Thanx bud. They might do .
