Sustain
HootsmonHootsmon Frets: 15978
edited June 2017 in FX
Think still got the blues or Parisian walkway or early Santana....
This tone possible at all with a les Paul and a clean "twin" type amp c/w an OD pedal,yeah?
Which pedal bub?
PS no compressors :)
tae be or not tae be
  • sweepysweepy Frets: 4189
    Compressor and a Boss Blues driver will get you close, don't neglect the finger vibrato and pick attack though, its not all in the pedals
  • english_bobenglish_bob Frets: 5160
    Digitech FreqOut claims to allow endless feedback/sustain. eBow might work, although on a bent note like on the songs you mention it might not work very well.
    Alternatively, a medium- to high-gain OD pedal, lots of volume and a little pre-gig experimentation with where to stand and where to point the guitar is the old fashioned way.
  • vizviz Frets: 10702
    Humbuckers, tubescreamer, valve amp and proper amount of volume and you'll get infinite sustain.
  • SassafrasSassafras Frets: 30301
    Rat?
    edited June 2017
    Sassafras said:
    Rat?
    He's a drummer.
  • Winny_PoohWinny_Pooh Frets: 7779
    Volume is it really.
  • mike_lmike_l Frets: 5700
    A Marshall Guvnor Mk1 will help, but you do need to be loud, it'll not work at bedroom volume.
  • Lots of volume is a big part of those tones I feel - it gives that big sustain without big muff levels of distortion.
    You can get it to sustain at moderate volumes with the right coaxing and judicious EQ, it doesn't have to be blow your ears out loud
  • AlvinAlvin Frets: 416
      Play in front of a fan , it can help and not a bad idea in the heat we are getting at the moment .
    Make sure you wear rope or leather soled shoes. Your body will absorb the Earth's magnetic energy that might otherwise be blocked by rubber soles. Your hands will become magnetised and act like an e-bow.
  • monkaiboymonkaiboy Frets: 27
    Lunar Module into a Minstrel gives me as much sustain as I need at low volumes...
  • professorbenprofessorben Frets: 5105
    I be never heard so much nonsense in my life.
    Everyone knows its crystals duh!!!!
  • ESBlondeESBlonde Frets: 3594
    Keep the amp bright and knock off a bit of treble at the pedal or guitar tone knob (one will sound better than the other because of the peak).
    He's already got the groupies,
    but the real fans take longer to find...     :o3
  • Modulus_AmpsModulus_Amps Frets: 2583
    With a twin type amp you may need a EQ pedal to push the mids a bit more, the Twin is generally very scooped out compared to the classic Marshall sound Gary used, the mids also help sustain
  • CarpeDiemCarpeDiem Frets: 293
    If you don't get the chance of using volume or playing directly in front of the amp, an alternative to a pedal is to fit a Fernandes Sustainer to your guitar. They generate sustain at any volume.
