I tend to start with a verb, then a delay, a pre amp at the start, klone, and a looper. Some on the top row, some on the bottom.
You can quickly see how id use 5 or so up (per row) - hence needing 10 switches...
If all that rambling makes sense...
…….That way you only cry once !
I originally wanted the rack version with the pedal controller and was looking to buy one off a forumite who currently adverting it for sale, but a failed MOT and the resultant costs put that particular wish to bed.
So far I'm really impressed with the LT, the routing is so powerful and the FX are excellent. I've started creating my own patches using the amp modellers and the results are amazing.
I was looking at perhaps using a small FRFR solution for home use and the Alto TX10 seems to be good for the money.
Any recommendations on budget monitoring?
