https://www.thomann.de/gb/lead_foot_aby.htm
The Bright Onion one is worth a look.
If you have a 'NOT 'EFFING TRUE BYPASS!' pedal and can solder you can make a simple passive splitter (post pedal) . If you run into hum problems you can diss' the screen connection on ONE amp feed.
Note, power each amp from the same outlet, even if the setup means you have to run an extension back to a common outlet. Do NOT use another mains socket because it is 'handy'.
And, if you do have hum loop problems DO NOT despite ANYTHING ANYONE TELLS YOU disconnect ANY mains earths!
Dave.
i have no clue how to go about modifying a suitable pedal,plus i don't have any pedals anyway
I have checked out Bright Onion,(thanks for the info) & they have a pedal which when i think about it is more suitable for my needs,which a signal splitter with phase switch & ground/isolation switch is £10 cheaper than there ABY box & since i will run both amps all the time(no switching),this is top of the list,unless someone pops up with an equal features cheaper solution.
Regards,Graham.
I might sell mine though - just down the road from warrington
What model(s) of Orange are they - are they the same? If so you can discount a phase issue.
http://www.thegigrig.com/humdinger-c2x17796080
Thanks,Graham.
http://www.brightonion.co.uk/active-aby-pedal-with-isolated-second-output/
It was great. Did what it said on the tin.
I've got one of the Bright Onion ABY active pedals, been using it for years with many different amp combinations, never had any issues with it.
