I agree with the geeking statement, well said. I have a Makita battery drill, both batteries are effectively gone west. Thus I found out about the cost of replacement batteries. The drill itself is easy to use, balances well, hand openable chuck with hammer action drilling capability. A great machine apart from the failed batteries. And I did follow the shops instructions on using and charging the batteries. I bought it three or four years ago. My Bosch mains drill is at least ten years going strong. It is more powerful than the Makita and has a better hammer action. Given the choice I would opt for the Makita if the batteries lasted much longer. For occasional infrequent use, a mains drill is the better choice as you do not have to think about or charge the batteries.
Nil Satis Nisi Optimum
They have taken five years of constant use in the Oil City workshop and have never missed a beat. They come with a fairly shitty selection of drill bits ... but I had hundreds of those anyway.
No. I have better things to do with my time than go around DIY shops checking out drills. IMHO, for occasional use, a mains powered drill is the best buy as it will always work as there are no batteries to keep cycled and charged. I use those tools quite a bit and find my battery powered Makita to be very useful. The batteries are the problem right now. Interestingly, a shop suggested me buying a new Makita drill and using one of the two batteries in my old drill. Possibly a workable solution as I hate chucking the Makita into the recycling bin. Over the past two years, I have recycled two battery powered drills and a battery powered sprayer. All due to failed batteries. One of the drills was an SDS machine and extremely useful, I now hire one when needed. As for the sprayer, I bought a Knapsack model. Talk about downgrading....
My point was (again) that mains drills are bigger and heavier than a battery drill that's perfectly up to this sort of work. Cordless has a significant advantage in that.
These supplies often have a lot of high frequency switching noise but I'd think the motor wouldn't care too much about it.
I was actually all set to buy a new drill - probably a Makita brushless. Are they not so good then? I see the ones they sell in B&Q for £150ish come with two batteries but reading the small print, they're only 1.5mAh, whereas the better Makita batteries look like they're up to 5 or 6 mAh now. Obviously the higher capacity batteries need recharging a lot less, so would presumably last longer for that reason. Supposedly the brushless drills use a lot less power too. Builders that did our extension used Makita drills all day and seemed to love them.
Anyway if I didn't have a drill and wanted to buy one I'd probably splash out on something decent and have done with it - it's just such a useful tool if you do a reasonable amount of DIY. One handy tip somebody told me was that you can tell if a cordless drill has a decent amount of torque by whether it comes with a side handle. I think you're talking £200 ish for something like that, though.
http://www.argos.co.uk/product/6161400
