Pretty easy to slip with a dremel...
DefaultMDefaultM Frets: 7344
https://i.imgur.com/Ac46ljG.jpg
Had to route the cavity a bit deeper to fit in this bareknuckle juggernaut and I slipped.
I'm not particularly bothered about it, I just don't understand why the pickups don't come with a disclaimer.
You could see straight away that its a very tall pickup, significantly taller than the dimarzio that was in there, so all I could do was route the guitar deeper. The guy before me also had to do the same.
2reaction image LOL 1reaction image Wow! 0reaction image Wisdom
    Nice bit of relicing there ;)
  • DefaultMDefaultM Frets: 7344
    Haha my first thought was actually "shit, people are going to think I've done this on purpose".
  • ICBMICBM Frets: 72440
    You are MD Phillips and I claim my £5!
    7reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • Jack_Jack_ Frets: 3175
    You need to have a clean around your knob.
    3reaction image LOL 1reaction image Wow! 0reaction image Wisdom
  • SassafrasSassafras Frets: 30294
    You should've taken the pickup out first.
    Well it is a 7 string guitar with only 6 strings on it.
    Exactly. I just assumed you hadn't got around to improving the string spacing yet.
  • stickyfiddlestickyfiddle Frets: 27115
    I've seen (and done!) worse. I once freehand-dremeled the control cavity in my strat to fit a new switch and push/pull pot. It's not a tidy job under that scratchplate, but I didn't manage to go through the back.. :D
    That'll be why your butt smells
    Honestly can't even tell if I've put these pickups in right. The middle position is supposed to be both humbuckers on full, but tapping the pole pieces with a screw driver the neck pickup is on full, but one coil of the bridge pickup is really quiet when I touch it.
    Is it one of those fancy Megaswitches, or a standard 3-way?
    What does the bridge position on its own do?
    Its a superswitch. The bridge on its own does sound a bit odd, but tapping it with a screwdriver both coils are on full.
    I think it sounds how its supposed to, which is very clear to a strange degree.
  • GagarynGagaryn Frets: 1553
    Been there, done that. I tape an old steel ruler along the edge I'm working on now as dremels always want to spin away from you.
    Could the bridge be connected in parallel in the bridge-only position?
    I once needed to go deeper into a pickup cavity, than my router would allow. So I decided to remove the baseplate, or whatever it's called, and do it freehand!
    I know..!
    Made a right mess, obviously. Thankfully, only of the guitar, and not myself!
    I can't believe I actually thought it was a good idea!
    I think this might be it. Parallel would be a lot louder than series but sound a bit weird on the top end?
  • FelineGuitarsFelineGuitars Frets: 11600
    Nope - parallel is quieter than Series - series  and out of phase is louder but sounds weird
    Did you translate the Dimarzio to BKP colour codes right or did you just copy the Dimarzio colour scheme?
    If it's the latter then that is your problem
    Also in 2HB guitars with a mega switch one pickup also needs to be mag-flipped (having the magnet in the opposite way when it was made - or at least before it is installed)
    Yeah, I think they were all the same except green and black. I definitely worked it out.
    Neck pickup sounds really good. Bridge pickup sounds sort of single coil like but in humbucker form?
    edited July 2017
    Think I'm going to take it all apart and rewire so that positions 2 and 4 are neck in parallel and inside coils parallel.
    Oh, so some of the wires were touching extra terminals by accident. Sounds fine now.
