Quick speaker ohmage question
BidleyBidley Frets: 2933
I'm using a 1x12 extension cab with my 1x12 combo. Both have 8ohm speakers. Is the impedance 4ohm?
  • MtBMtB Frets: 922
    Here's the answer - depends if they're wired in series or parallel:
    https://www.eminence.com/support/wiring-diagrams/
  • ICBMICBM Frets: 72497
    Almost all amps with two speaker jacks have them in parallel. If it's one of the rare ones with them in series it will almost certainly say so, since it would otherwise be assumed that they were parallel.
    Short answer: yes, 4 ohms.
  • DJH83004DJH83004 Frets: 196
    You don't state the make / model you have, some manufacturers switch the output transformer tap to 4 ohms, when the extension speaker jack is plugged into the extension socket, whereas others tolerate the impedance mismatch, as IC says almost always in parallel
  • BidleyBidley Frets: 2933
    edited July 2017
    @DJH83004 @ICBM The amp is a Carvin XV112. Two speaker jacks, switchable ohmage. Cab used to be a Valvestate combo of some sort (has a Marshall-branded Gold Back in it) wired in parallel.
    So, the internal speaker is 8ohms, the extension cab should have 2x16 ohm speakers in parallel e.g. 8 ohms, therefore plug the extension cab in, and slide the impedance selector to 4 ohms, all good  :)
