My Brother in laws SOUL FOOD has gone wonky....the switch it would appear....it says on it (on the 3ptd switch) "true bypass and buffer"
What's that all about ...is there something different about the SOULFOOD or is that par for the course for a 3ptd switch?
Is a new switch easy enough to solder up?
Is there a selector for TB or buffer?
Most TB switches are 3pdt (3 poles, double throw) and are easy to wire up. Even I can do it. Fuzz dog also does a mountable PCB which makes it even easier!
You can replace the fs if you are very careful.
brother I law has unsoldered one end of the ribbon that's attached the assembly....he knows shit about these things though.....has he effed it up you think?
