Yes, had a 75 for years, reliable, portable, loud. Have no desire for anything else.
It's not a good amp if you need a pedal to get good tones.
"The Blues Cube series is a discrete (analog component) class A/B design and the Katana is an IC (DSP) class A/B design. The physical power amps for both are class A/B and both dynamically interact with the live speaker as do tube amps."
"both are class A/B and both dynamically interact with the live speaker as do tube amps." < Probably means there is a low value resistor in the earth side of the speaker circuit that introduces negative CURRENT feedback which gives the amplifier a higher output impedance than the buggerall that sstate amps naturally have but valve OP stages don't.
"Dynamically Interact" ?? Yeah, well....
I think I might start a collection of these manufacture's adpuff phases? Many here will understand why!
Dave.
You mean like "current feedback"?
