Clarky and the Helix
  • RolandRoland Frets: 8780
    6db makes sense. A 12db filter at 4.5khz would generally leave very little high end - it's always ears before eyes at the end of the day though.  I think the Fractal does either 6 or 12db.
    Fractal can do both 6 and 12dB per octave. I normally use 6
    Clarky how do you go about creating a patch?  Do you have any EQ tricks that you generally use to get you started?
  • ClarkyClarky Frets: 3261
    edited July 2017
    Clarky said:
    some interesting comments…
    I'll certainly be trying some of these suggestions..
    so here's why I need 3 amps
    riff = 2 hi-gain amps panned hard
    solo = 1 hi-gain amp panned centre / delay / reverb
    clean = 1 clean amp panned centre / reverb
    this looks ok.. I can have 1 hi-gain amp in path 1 and the other hi-gain and clean amps in path 2
    and use snapshots to switch them off / on and pan them [although I've not tried that yet so this is all theoretical]
    so at it's most basic level, these are my tone switching requirements
    sorted
    path 1A: amp1 / pan
    path 1B: col / amp2 / pan
    path 1 -> path 2
    path 2A: amp3 / dual cab
    snapshot1 [riff] = amp1 active: pan=left / vol=bypass: amp2 active: pan=right / amp3 bypass
    snapshot2 [solo] = amp1 active: pan=bypass / vol=0: amp2 bypass / amp3 bypass
    snapshot3 [clean] = amp1 bypass: pan=bypass / vol=0: amp2 bypass / amp3 bypass / amp3 active
    next experiment will be to control parameters via snapshot
    essentially get amp1 cooking in snapshot2
    Did you try simply switching presets?
    yes.. and typical with modellers you get the gap in audio as the DSP's reload..
    this is where the snapshots come into play..
    same with scenes in the Axe-FX..
    the tone transition is immediate / seamless and you'll preserve the tails of ambient fx..
  • robinbowesrobinbowes Frets: 3056
    I asked because, in a live situation, I don't find I notice any gap. But I guess it depends on what you're playing and when you change sounds.
    R.
    R.
    I seriously notice it.. and have gone to great lengths in every multi-fx unit I've had to eliminate it..
    when it comes to changing presets seamlessly, the 2120 still wins hands down..
    a unit from the early 90's still kills them all
  • VaiaiVaiai Frets: 530
    When controlling parameters in snapshots if you press down on the knob while turning you get square brackets round it which show that parameter is just for that snapshot. Dead easy to set them that way
  • Si_Si_ Frets: 384
    I've never managed to get more than 2 amps on a preset, my main patch only has 2 and I have to make compromises because of it :(
    I know this is kind of off topic, but in order to get this to work on the Axe FX, I assume you use X/Y on the amps. Do you not notice gaps when doing this? If not, how do you go about setting this up to work gapless on the Axe FX? Many thanks.
  • kjdowdkjdowd Frets: 852
    AX8 you have to use XY and there is a gap. Full fat axe fx has more DSP tho so you can have more than one amp in a patch without XY. Or at least so I understand.
    Yes, that's correct, I typically use two amp blocks on the Axe FX II XL, but must admit, have never tried the XY approach in fear of "a gap"! Would be cool to try when I get home though. I think this is the reason I couldn't fully commit to the AX8, seems a real shame that you can only have one amp block.
  • stratman3142stratman3142 Frets: 2206
    Have you tried sharing the amps between path A and B?
    It's not a competition.
    I found I could only place 2 in a single path
    I get around it
    the transitions that matter most are riff -> solo and clean -> solo
    the amp for solo is in a different block to the clean amp and is the same block as one of the riff amps
    clean -> solo is a change in signal path, riff -> solo bypasses one of the riff amps and changes the pan in the other
    the only transition that has a gap is clean -> riff because amp2 has to flip Y->X
    the clean tone has a nice big reverb so the trails mask that..
    so essentially… there is never a gap
    that's exactly what I did..
    I get around it
    Great stuff, thank you! I had a feeling you may have used trails to mask it.
    Tis the reason I'm considering moving from AX8 to Axe FX II XL...
    I get around it
    the killer thing is to evaluate what you need rather than what the unit can do..
    these transitions are most common and I've made them seamless
    riff -> solo / solo -> riff
    clean -> solo / solo -> clean
    clean -> riff / riff -> clean only happens in 2 songs in the set
    in one song [Starless and Bible Black] there I have a 2 bar rest to get from clean to riff… which is easy.. lol..
    in the other [Exiles] there is no gap clean -> riff which is filled by the reverb tails
    and no gap riff -> clean.. this is the one that is most exposed so I mask it in the performance itself by 'throwing away' the power chord which leaves a logical 'rest' of 1/8 note.. so in this case the transition is 'apparently seamless'..
    Tis the reason I'm considering moving from AX8 to Axe FX II XL…
    I tried the AX8 and couldn't make it work for me..
    yes it has all that beautiful Fractal modelling - which to my ear is still far superior to everything else..
    but there's a lot of other stuff missing in the control areas..
    folks talk about it like it's an Axe-FX with only one amp and one cab..
    in reality it seemed to me to be a bit less than that..
    sure it'll be a fabulous unit for a great many folks, but not for me..
  • @Clarky how are you finding the modelling on the Helix now you've spent more time with it? I agree that the Fractal sounds superior to most of the stuff I've tried too.
    What band do you play in, by the way? If you don't mind me asking.
