Cleaning a Record with Wood Glue
RabsRabs Frets: 2610
in Off Topic tFB Trader
«13
  • fandangofandango Frets: 2204
    Reminds me that conservationists did something similar using latex to a whole wall of the Great Hall in The Palace of Westminster (Houses of Parliament) to clean the stonework. And by gum it worked. They then hung the latex sheet intact with all the dirt on the back for all to see. That was wow!
    As for this Miles Davis record, there is some improvement prior to the music, but cant tell much different after he starts playing. But then i am not listening on expensive hi-fi equipment.
    Love the way the chap in the video uses Titebond glue. There must be a Gibson link somewhere in this.
  • SimonCSimonC Frets: 1399
    I wonder if you flipped that glue disc over and put it back on the turntable if it would play in reverse.
    Handy for all those Led Zep hidden messages.
  • chillidoggychillidoggy Frets: 17136
    Jazz - no improvement to my ears. It's all bad.
  • Emp_FabEmp_Fab Frets: 24387
    Put the record in the bin and just download the MP3.  Problem solved in ten seconds.
  • RavenousRavenous Frets: 1484
    Heard about this idea many years ago... but have never had the nerve to try it.
    Maybe I should dig out a single and have a go...
  • BigMonkaBigMonka Frets: 1779
    That's pretty clever, although using that amount of glue on each side of each record is an expensive way to clean them!
  • jamiexsilverjamiexsilver Frets: 404
    Yeah I do it, very hit a miss results though sometimes they sound better sometimes there's no difference what's so ever. Use good glue though and it takes ages to dry.
    These are the pictures of the last one I did.
  • bloodandtearsbloodandtears Frets: 1656
    Blutac is known to work well too
    My trading feedback
  • WezVWezV Frets: 16736
    is this like charging your phone in the microwave ;)
  • RockerRocker Frets: 4987
    This is the daftest suggestion I have ever read...
    Nil Satis Nisi Optimum
  • SteveRobinsonSteveRobinson Frets: 7046
    It would surely sound better if they used hide glue?
  • robgilmorobgilmo Frets: 3511
    Play your records wet, really, goovle it
  • vizviz Frets: 10706
    edited July 2017
    Once you've played it wet you'll never be able to play it dry again because you boil in all the crud into the groove (I think)
    Yeah thats what I read, the trick is never use tap water, even for cleaning, it dries and leaves calcium on the record and causes crackling, buy battery top up water from halfords, its well cheap, I did it a few times.
  • impmannimpmann Frets: 12668
    Seriously, this works well if you use the right glue. The physics is simple - a pva glue will not stick to the plastic used in the vast majority of LPs and 45s. Don't use it on Shellac (78s) though...
    The glue dries and all the grot in the grooves is gripped by the glue. You peel it off and the grot goes with the glue. Simples.
    I had an original copy of Aretha Franklin Live at the Fillmore West that had been unplayable for years - so much surface noise. I'd even paid for 'professional' cleaning that improved it but it wasn't great. I tried the glue trick and now its perfect.
    However, be aware that using glues that aren't quite as good as they were can be a nightmare. I tried using some Titebond that had been open for a while and it was impossible to remove in one piece from the disc. I've since redone it with a fresh tub of Titebond and its removed the grot and the scratty pieces of glue.
    I've had the best results with Titebond II (blue) but equally cheap PVA works well.
    A new stylus for my cart is 185 quid, I wouldnt risk it.
    Not far off the same here. :-)
    No risk - certainly no more risk than playing a s/h record you bought at a record shop...
    Bit like those pore strips you get to remove blackheads from your nose.
  • mellowsunmellowsun Frets: 2422
    edited July 2017
    I reckon you should be able to play the dried glue disc on a turntable just like one of those Flexi-discs you used to get with Smash Hits.
  • GagarynGagaryn Frets: 1553
    Read about that a few times but seems a hassle. I have a Knosti Disco Antistat and they work brilliantly. Make my own fluid 80% distilled water, 20% IPA and 5ml wetting agent for a litre - I use Ilford Ilfotol. Works out mega cheap and is as good as any commercial fluid I have bought. I recently replaced my Ortofon 2m Blue with a Audio Technica VM740ML which has resulted in much less surface noise even with fucked second hand records - pretty much all my vinyl plays now with zero pops or crackles.
