Does anyone get problems with particular brands of strings having intonation problems?
I've been using Newtone for a year two after some recommendations on the old MR forum and they do sound good, and it's good to support a British maker, but I recently had a D string that was way off on intonation. I was wondering if other people had had similar issues, or whether it's just a one off.
I'm tempted to go back to D'Addario, but if it's an isolated issue then I might stick with the Newtones.
There was a thread on another forum where someone was complaining about issues with intonation on another brand as well so this could be a wider issue than just one brand. Are there strings that give consistently good intonation, or are there ones that people have regularly had problems with? What is everyone's experience?
I think you kinda pay for consistancy when you buy strings but if you found one string that was off after 2 years then your not doing too badly ...I normally tweek my intonation with every restring if im recording or if one of my fussy muso mates is coming round
I used to go to Mountain gigs and shout at him for 2 hours solid:
"Leslie!
It sounds Off!
You can't use a Plain G with a wrapover compensated for a wound string!
You can't do that!
Leslie! "
Fortunately no one could hear me above the roar of the audience......
It was more that kind of thing I was after. Does this happen regularly with certain brands or was I just unlucky with that one?
I don't remember a string that bad in more than 20 years with D'Addario.
Buzz Feiten Tuning System. Problem solved.
Nil Satis Nisi Optimum
Instagram
Ear defenders solved mine.
