Les Paul Prototype Build
  • WezVWezV Frets: 16726
    I was reading a 52-59 LP conversion thread the other day.  its fairly brutal stuff that might make some wince, but the work looks great and I am not trying to start a conversion debate here
    http://www.lespaulforum.com/forum/showthread.php?171038-52-59-Burst-Conversion
    The reason I am linking it this is because it shows the bits a Golden age gibson (in terms of wood and construction quality, if not design quite yet) you don't often get to see
    like this pic - with a fairly large shim going down the entire bass side of the tenon
    doesn't stop it being a beautiful guitar,  you would find similar in gibson's from all ages.    But it does show the difficulty Gibson have always had in getting this join right.
  • DanielsguitarsDanielsguitars Frets: 3297
    Yeah it's all good wez, alot of the old stuff was slapped together but I still love em
    Most modern mass produced stuff I've tried just feel boring, I'm still chasing the unplugged tone
    On the subject of tenons, I've got a build planned out at some point for a dc junior style but with a flying v type joint with the heel on the body, it's to get a strong joint if I want a 59 style neck pickup placement
    The narrow long tenons I did on my strat and tele styles came out really nice and I'd do them again
    I don't like losing the side wall on the body that's all and from a finishing point of view I don't like the look
    www.danielsguitars.co.uk
    (formerly customkits)
  • TTonyTTony Frets: 27620
    Interesting photo.
    Not getting into the whole debate about pros & cons or rights & wrongs though!
  • GSPBASSESGSPBASSES Frets: 2351
    edited August 2017 tFB Trader
    TTony said:
    Interesting photo.
    Go on you know want too.
    When are we going to see the new work shop?
    edited August 2017
    GSPBASSES said:
    @WezV Sorry, I'll shut up now and leave this post to the real thing about you making your prototype Les Paul, and I must say is most interesting.
    Always grateful for the input.... sounds like we have a similar approach, but for slightly different reasons.
    Anyway, worth restating my intentions with this build.  Its not to prototype my own line of les paul style guitars.   Its to do things the way Gibson might have done in 51-52 whilst avoiding the mistakes of the 52  les paul.  Not the documented ways they did do it - but some of the steps they might have gone through to get to there
    So far i have majorly diverted with a sycamore top and a laminated neck.   I am okay with that and may divert in other ways
    But i did show you all a 51 prototype to demonstrate gibson were playign with the full width tenon back then, even if it only ended up being on that guitar
    not quite right though is it - they have not done the full lip of the juniors/specials but left quite a hump on the transition.  Also, they have made the heel quite a bit larger and its not really needed.  I also wonder about the two inlays - possibly covering screws, if so why
    So a full width tenon is fully in the spirit of this project- but not the way they did it in on the 51 guitar
    just so happens the full width i did on my last guitar looks to be the perfect hybrid between the 51 prototype and the eventual and classic les paul design
    i think the gibson tenon design relies on those 2 side faces of the join, whereas the full width tenon  favours the bottom face of the join.
    Its clear from the gibson examples that they often sacrifice a good fit on the bottom face of the tenon as part of getting the neck fit right.  The short rocker tenon takes that to extremes and almost totally sacrifices the lower glue surface.  Even that example, the worst tenon  design, will still work as long as the side faces are a good join.   the side faces are your glue surface, the fretboard  and neck heel sets your reference angle
    You can't ignore the base of the tenon when going full width, it becomes your primary glue join and your reference point for the angle.
    In short - what you lose in one location, you more than gain back in another
    But yeah, i would agree the gibson solution is more aesthetically pleasing than my full width join above.  I just chose to place that factor lower down my list of priorities
    Nice pics
    in other news - Special instructions from @SteveRobinson ;
    8reaction image LOL 0reaction image Wow! 1reaction image Wisdom
    the neck is a bit further along - not happy with the headstock veneer so that will change in some way even if its just being sprayed black later on
    Next steps are to radius, inlay, fret, carve, drill etc....but its all prepped and is currently a consistent thickness of 24mm along the neck shaft
    I can route the body for it at this stage as all the important dimension for neck angle are correct.
    New new tailpiece is here too.   its maybe a little too long - but they are easy to shorten if i need to
    I don't ignore the bottom of a long tenon as I too think that is a very important gluing surface, i dont care how gibson do them, if the joints not right it's not good and that goes for any type of narrow or full width tenon
    I don't prioritise weather it looks good it's just what I use and I'm happy with how they work
    A joint to me is all the surfaces available being correctly fitted and used
    edited August 2017
    Haven't we done with this?
    at no point did I suggest yours were not fitted correctly or that it was a substandard method.   I am not going to post a load of pics proving my point here.  Just google gibson long tenon and enjoy all the pictures of gaps.
    I know of the banana tenons and crappy joints, anyone that's any good would try and get it as good as possible before gluing
    I'll shut up now and see how yours turns out, get some sound clips up if you can
    edited August 2017
    here is the full width mortice all routed
    Still need to do the binding channel in the cutaway, once that's done I will trim down at least a 3rd of the treble side to make it nice and neat - similar to a fender neck join.  That's the glue joint I sacrifice for this.
    The neck slots straight in nice and tight, but not so tight i cant get it out again.- no more  fitting needed
    It starts to look like a guitar
  • normula1normula1 Frets: 640
    Looking good.
  • IvisonGuitarsIvisonGuitars Frets: 6840
    Nice work Wez. I may have missed it but is your neck angle in the pocket like a Standard or on the neck tenon like a Junior?
    http://www.ivisonguitars.com
    (formerly miserneil)
    edited August 2017
    I angle the pocket on a carved top like this, angle the tenon on flat tops.  If you look at the maple you can see it
    The body angle has already been done as part of the carve.  I use an extra long template that sits on the body angle, but is also supported by blocks either end to keep the angle consistent
    however, worth noting that I still have a flat fretboard as a point of reference and could tweak the heel angle if I had messed up the body route.  Thankfully it's still spot on 4 degrees
    routed for the pickups - happy to see the wiring channel where i left it :)
    which gets us to this point
    decisions at this point.
    I have decided that tailpiece is definitely the right one.  I am still not sure about the bigsby bridge.  I would need one staggered for a plain G.   I quite like it, but wonder if it makes the whole thing a little too gretschy.  I am not even sure that's a bad thing
    I am starting to think about controls and I am still slightly tempted to go for a non-standard layout as used by les, but would not be putting a jackplate on the front.   I don;t know whether to do a front mounted jack in place of a pot, or just write it off as a silly idea
  • TeyeplayerTeyeplayer Frets: 3222
    Loving this build. For what it's worth and I'm no luthier just a player, but I've always wondered if a combination of Gibson and Gretsch would be the perfect guitar. So many qualities and so many niggles ironed out when combined.
    Well given the pickup choice its really not going to be a million miles from this
