Is this worth a punt? Epiphone valve content
LegionreturnsLegionreturns Frets: 7965
Biding my time looking for my first valve amp, but this has appeared at what looks like being quite a good price. Anyone used one?
 http://www.ebay.co.uk/itm/162624533372
  • They're not amazing sounding in my opinion. For a good low price valve amp, something from the jet city range is probably more suitable.
    There used to be a jet city combo with a proper clean channel (sadly discontinued) and the custom 22 head has a clean channel too. They're about as cheap as valve amps get for decent channel switching.
  • Ok cheers, I'll leave it then
  • 57Deluxe57Deluxe Frets: 7339
    edited August 2017
    They are a bit one dimensional, but if no-one else bids and it has good valves, then maybe will do a trick for you on the cheap... as long as you not into metal.
    If you go the Jet City head root, then a separate cab will be required.
    <Vintage BOSS Upgrades>
    I've got pedals, a good clean sound and pedal platform is what I'm after.
