Blood stains
mine - from nosebleeds into a handkerchief
Tried the Ariel spray stain remover, left it on for quite a while, washed in washing machine (whites at 60C) ... still stained :(
has anyone any other ideas?
  • BucketBucket Frets: 7751
    edited February 2014
    Industrial carpet cleaner, wrap the body in rug, dump in canal.
    4reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • boogiemanboogieman Frets: 12383
    Buy a new hanky.
  • bertiebertie Frets: 13569
    soaking warm salt water always used to work for me, but needed to be done asap before washing................but as you've already washed it in "hot" water, unlikely to know work... or little devil stain removers - they're pretty good
  • fretmeisterfretmeister Frets: 24411
    Fill your nose up with Silver-nitrate. That will cauterize it.
    Or even better - get a doctor to do it for you. Hurts like... getting a burning liquid poured into your nose. Funnily enough.
  • mike_lmike_l Frets: 5700
    Firstly, get a new handkerchief, they ain't expensive.
    Second, if you're having repeat nose bleeds, go see your doctor. Something's wrong.
    yes you're right but at the time I was not able to do that, and it had dried on. I have in the past been lucky enough to soak in warm salt water before it got dry but not this time ...
  • boogieman said:
    Buy a new hanky.
    Nooo! It was my favourite Homer Simpson hanky !
    should have tried before washing - that can "bake" it in so to speak.............  try the little devils as I said :)
  • SpiderSpider Frets: 130
    3 for a fiver
  • Wouldn't be the same, Spider. I blubbed into that one when my dad died.
  • chillidoggychillidoggy Frets: 17136
    I had a cauterise procedure done on NYE after suffering nose bleeds. Walked out of the hospital and immediately had a nosebleed! But the cauterising procedure was painless, and I haven't had any since.
  • Luminol is great for blood stains.
    Oh, a very special one then, I just used my sleeve when my old man died, I've got some hankies somewhere just never use the things.
    Keeping a snot filled rag in my pocket just seems wrong, as I suppose is using ya sleeve. :-/
  • Stop bleeding you great nancy.
  • wibblewibble Frets: 1108
    Use paper tissues.
    Hankies are so unhygenic! :D
  • RockerRocker Frets: 4985
    Kleenex. Go see your doctor. In that order.
    Nil Satis Nisi Optimum
