Humbucker sized pickups for Mustang?
I've got one of those Cheapo Squier Bullet Mustangs.
Really like the guitar so thinking about doing it up a bit: any recommendations for humbucker sized pickups? I want something for the whole punky / alt-rocky / grungy stuff like Nirvana, Dinosaur Jr etc.
Was thinking perhaps something p90-esque but really not sure...
Bear in mind this guitar costs £115 brand new so custom winds from the usual suspects are probably not going to happen!
  • FunkfingersFunkfingers Frets: 14447
    Measure the pickup cavity. It is a generous rectangular "swimming pool". The critical dimension is the depth. Humbuckers with full length elevator screw lugs might not fit in.
    The usual suspects are the DiMarzio Super Distortion and Seymour Duncan SH-4 JB.
    Your P90-in-HB-size idea might work. The HS format associated with Kurt Cobain is more versatile.
  • AlegreeAlegree Frets: 665
    JB won't get close to Nirvana. You definitely need something 13k-14k with a ceramic mag for that.
    I've got lots of humbucker winds left in my deal if you can find a colour combination to fit. http://www.thefretboard.co.uk/discussion/106698/many-made-to-order-pickups-available-at-discount-see-explanation
    My Firestorms are the punky / classic metal go tos in my catalogue.
  • earwighoneyearwighoney Frets: 3497
    I'd go for one decent pickup instead of two if you don't want to spend that much.
    I have a HB sized P90 from @Alegree and it is great.  Works well for fuzz tones and clean.
    edited August 2017
    Interesting point of view
    This post suggests that Cobain used JB in his Mustangs......
    http://www.seymourduncan.com/forum/showthread.php?205879-Mustang-with-Cobain-customizations
    I have a JB in my Squier Bullet Mustang and it grunges up very nicely just driving the amp...
  • PhilKingPhilKing Frets: 1481
    Was it an original JB or a current one.  I have a really old JB in double cream and it measures 14.1k, which is very different to the current ones.  It also sounds totally different.  The Bare Knuckle Rebel Yell is a lot like it in sounds, but probably outside your budget for this change.  You want an slightly asymmetrical wind, with A5 magnets, wound to about 14k, not the 16.6 of the current JB.
    edited August 2017
    Interesting...
    edited August 2017
    Based on the previous replies I might try one of these in mine
    http://www.irongear.co.uk/irongear_pickups_008.
    or one of these
    http://www.irongear.co.uk/irongear_pickups_029.htm
    Cheap enough for a punt, if a little on the hot side....
    Or you could buy mine for a fiver more for a lifetime warranty, free swap period, greater resale value and a better sound.
    So which pickup from your range would you suggest - black uncovered.......
    My suggestion is above. Black uncovered isn't included in my deal though.
    Covered won't fit, or suit the vibe....Iron Gear it is then!
    I've got loads of uncovered combinations left.
    So what do you recommend? Something rude for a short scale mustange bridge?
    https://www.alegree.co.uk/collections/humbucker-sized-pickups/products/firestorm
    https://www.alegree.co.uk/collections/humbucker-sized-pickups/products/heat-wave
    The first is my take on the super distortion, the second is my take on the JB. Either would work for an aggressive rock sound. I've got zebra or white colour combinations left in my deal. Side note: Heat Wave is standard slug/screw format despite the photo that I need to replace.
    Is your JB like the "old JB or the "new JB"?
    It's based on the new one, but I wouldn't say it's 'like' it. I've improved the original design a lot.
    Even amongst the fanbois on the Seymour Duncan User Group forum, the SH-4 JB was often a bone of contention.
    People seeking to sell older specimens would have you believe that older is better. Some seem in awe of examples of this model that have been wound on a machine under the guiding hand of long-term employee, Maricela Juarez.
    Over the years, I have owned a couple of SH-4 humbuckers with the JBJ model identification label on the baseplate. How different these sound to examples with the current Duncan production sticker, I could not really say.
    Does the output cable type change the sound? Does the length of the elevator screw lugs make any difference? Does direct mounting into the guitar body à la Edward Van Halen make any difference?
    Some pickup experimenters demonstrated that changing the polepieces and/or the magnet formulation made a difference. The JB with an Alnico 2 bar magnet sounds not a million miles away from the old SHAH-1 Allan Holdsworth model.
    Does any of this matter? Probably not. Does it matter what Kurt, Eric or Yngwie use? Probably not. Create your own sound.
    Agreed. It seems to be a real marmite pickup. I know which side of the fence I sit on with it. As much as I tried I just couldn't get past that horrible high mid whine, which made it impossible to dial in any decent tones at all.
    So I wound a similar pickup differently to keep the general characteristics of it, but get rid of that horrible high mid hump. I suppose that's probably one of the key characteristics itself, but I certainly find mine more usable.
    I think the JB is primarily used at both ends of the distortion spectrum - from pop punk (Green day) to metal (Megadeth). It doesn't really sit well in the middle ground in my opinion. That middle ground is my main interest, so that's perhaps why I detest it so much.
  • Thanks for the advice guys.
    I'm having some work done on another guitar is just now so need to see what the damage is on that before deciding what to do with this one. I think that I might just replace the bridge pickup and then wire it just for volume and tone, it will cut down on the expense and hassle a bit.
