I put this track together using the Helix Floor Hardware version plugged into the DAW (Sonar Platinum) and then created the same track using Helix Native.
I used my Plexi Crunch Patch and played the parts separately. I've tried to match the levels as best as I can but other than that there was no post processing.
I brought my patch into Helix Native and tracked the parts. I set up my audio interface so that there was no latency and played as though I was using the hardware Helix.
I then re tracked the parts with the same patch in the Helix Floor and recorded them again.
I'm really impressed with how close these tones are (I know that Line 6 has said that they're supposed to be identical but I just had to see for myself)
Cheers
Peter.
Helix Native
https://soundcloud.com/peter-john-hanmer/helix-native-plexi-crunch-1
Helix Floor
https://soundcloud.com/peter-john-hanmer/helix-plexi-crunch
EDIT: Ah, I dunno, there's not much in it at all is there really! Maybe my ears are playing up! Either way, good job!
I've not listened to the clips yet but I'd be surprised if there was enough difference to care about, if there's even any difference at all
Yes. Should be identical then. Same input and output stages and the same sums being done in the middle.
