SOLD - MJW Electra Grind Mint Condition
Recently bought off
@SidNewton and I instantly fell in love with it but couldn't resist picking up a Bad Cat so now this has to go unfortunately.
Based on a Marshall Plexi with a boost switch to take it to high gain JCM800 levels
This is the 50 watt version
Mint condition, the last owner had barely used it and it's seen a handful of rehearsals and 2 gigs since I've owned it.
Comes with a roqsolid cover.
This particular model had a mod carried out to the master volume. In Martin's words:
That particular one was modified post-sale to change the PPIMV to pre-phase-inverter, as the customer found he didn't like the decreased effect of the presence control at lowish settings and was happy to sacrifice the PI overdrive. I spent the day in Wales tuning the amp to his taste (FOC!) so it'll be interesting to get a new take on how it sounds".
I'm looking for £400 collected from Walsall, West Midlands. Or I can meet within reason for some petrol tokens.
http://imgur.com/c9dcs9Thttp://imgur.com/dRWTOb3
is the boost footswitchable? Does it have an effects loop?
Cheers Steve
At lower volumes I found in normal mode ie boost off it doesn't break up as early but I got round that by using it with the boost on and using a lower gain setting to get the same level as boost off and volume up. Saying that i'm not sure the MV position made a difference there, more me pushing the output stage a bit harder with it up.
And no I'm not in London very often I'm occasionally down for work but not so much recently.
At lower volumes it just needed a little more presence added i found to get around any loss in 'grind'
