Anyone tried making their own ear moulds?
    Emp_Fab said:
    How do you mean?  Tape where?  I'm imagining a two inch wide band of duct tape around my head like Rab C Nesbitt.
    Make sure it goes over your mouth too.
    And up yer arse.
  • Emp_FabEmp_Fab Frets: 24351
    edited September 2017
    Hey, you've just given me an idea for a combined sex toy and throne thumper for drummers.
  • Danny1969Danny1969 Frets: 10419
    The Shures normally come with the soft foam and hard foam buds of different sizes, I like the hard rubber ones, looped over ear and then small bit of tape stops em coming out. Some people like a little lube :)      :-1:
    https://alclair.com/monitorshop/ear-gel-lubricant/
  • Emp_Fab said:
    have you tried all of the different tips and none of them make a good seal? I got like 10 different ones with mine
    I had the same set of tips but I've only tried one size so far. It's not that they don't make a good seal but that they hurt after an hour.  I also don't like the pulling of the weight of the wire on the back of my head - it keeps pulling them out slightly.
    I wonder if silicone sealant would work and whether it would harm my ear while curing ?
    You can shape the firmer bits near the actual drivers so they hook onto your ears and relieve the weight
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    You put tape over your ears ??
  • SporkySporky Frets: 28404
    You don't?
    Er... no actually.
  • Emp_Fab said:
    @stickyfiddle Are you talking about the squeezy yellow foam ones?
    The ones that came with mine were a dark grey. I have three different sizes
    Yeah, I've got those too.  However, experimenting last night I discovered a likely reason for them hurting...  the two halves of the plastic casing on the left one (and a bit on the right too) did not line up perfectly.  There was a tiny lip / ridge that was irritating my ear.  A quick Dremel later and I think I may have sorted it.  Only time will tell.  I'll find out on Wed when I use them at band practice for several hours.
    You Dremelled your ears?
    This thread is turning out better than my greatest hopes.
